Superglue seems to gush out and get everywhere - I had to buy acetone to dissolve it, because it happened so often (and acetone doesn't dissolve it terribly well). @PC2017 Fair comment, I'll stick with this self-portrait for a bit.I tried super and got it everywhere - @guerney keep changing your mind on your pic much
Not just me then - keeping the tube stored upright prevents lid sealing and initial over spill but not from getting it everywhere thereafterAnd got glue on my fingers but that was because
I like it - Tbh I must change mine, I have my black controller dawned with gold heat-sinks to rescale.I'll stick with this self-portrait for a bit.
They wouldn't sell very much if people managed to squeeze out tiny drops like in the adverts - making superglue tubes single use by design is far more profitable. Perhaps using a chemical emulsifier to produce an easier to apply consistency similar to UHU, would result in a less super glue? Even if by some miracle I manage to not splash it all over like the Henry Cooper, it's turnd solid by the time I need it next, unlike UHU which manages to store for years between uses.Not just me then - keeping the tube stored upright prevents lid sealing and initial over spill but not from getting it everywhere thereafter
You've got GOLD heatsinks?!?!? Where do you live? Next,I'll need to locate someone who owns those even more heat conductive diamond heatsinks...I have my black controller dawned with gold heat-sinks to rescale.
It's all that penny pinching I do Darn - just found out it's fakeGOLD
If you haven’t already done so, cover up the exposed Yellow and Red connectors to prevent water / dust / debris getting into them.Hello everyone, I'm leeroy and this is my first foray into the world of ebikes! I have to say I've enjoyed reading the many posts here and gained quite a bit of knowledge!
This is my planet X jack flash 26" with a 250w yose power front hub kit, I've had a spin around the block and it's a lot of fun, I'll only be using it for on road in the dry.
I'm just waiting for some more velcro so I can get rid of the (temporary) tie raps and hold the battery down better. I'm also waiting for a longer wolf tooth mount as I decided not to use a rivnut, maybe I should?
Well spotted! I put self-amalgamating rubber tape over my unused throttle connector - it was pointing upwards and asking to get filled with rainwater.If you haven’t already done so, cover up the exposed Yellow and Red connectors to prevent water / dust / debris getting into them.
Hi! The silver bike has super moto x tires and the black one has Land Cruisers, both by shwalbe and both the in 26”I like these tyres, what are they please?
I use the above, there are darn good tyres, I run with slime they have good puncture protection on the side but tops are prone to a thorn or two.Land Cruisers
The "super" from Schwalbe? yep they look fast n slippymoto x tires
Yep the super Moto x, there actually quite grippy, I’ve never had the front wheel wash out or slip on power even on sandy roads and towpaths. I’ve never used them in the wet though.with all tyres I watch out for wet manhole covers, slippery as...
