New Conversion kit launching
gw8izr
239
252
1. you will have to replace your chainring with the new chainring because the clutch is built inside it, so you can't reuse the old cranks anyway.
2. how would you fit the chainguard?
Well you’ve edited your response since I posted mine so I’ll back out of the discussion at this point.
17,122
Something about this drive design appeals to my engineering background
how do you compare this part of the design to another kit like yours?
17,122
I know you are very good, I saw the replacement front arms that you made for the rack battery on your bike. Since, I bought some aluminium profile just in case anyone needs to make replacement arms.
harrys
381
106
Chicago, USA
My first conversion was a rear hub motor and uneventful. Second one was a BBS02, memorable because the crank arms were fused to the BB spindle. Took a whole day to remove.
At my age, I've learned some patience. My current conversion(s) involve two wheel builds. Looking at 1/2" in wobble and 3/8" radial variation when I started to true the last one, I kind of wondered if the wheel was going to win. Nah.
17,122
I know the feeling.
We have often to use a thick plate, two wedges and a big hammer to push the crank out.
Reactions: Audio2
Matteo from Bikee Bike
21
If you install a Bafang BBS kit for example on a bike with triple chainring, you can disconnect and leave the front derailleur on its granny ring setting without having to remove it.
If you want you can leave the derailleur on this one as well in the double chain configuration ( as GNG): you can have a triple chainring and use the derailleur to switch from the bigger to the medium one and keep the smaller chainring for motor-to-crank transmission.
I believe that the most important thing for a retrofit kit is its comfort and performance while riding. Installation just happens once or twice and if someone feels it's not able to do it, then he can handle the bike to a bike shop for doing the least obvious passages ( such as taking down the bottom bracket).
17,122
Hi Matteo,
that bike is a specialist build, perhaps for the showroom only.
The average kit looks more like this:
that picture was extracted from one of gw8izr's posts.
BTW, that Rocky Mountain has 3 chain tensioners instead of one.
21
I have friends which have been using it for one year and it's doing very well.
They have one more than our system: the third one at the top. That's probably used to get a desired behaviour of the rear suspension rather than for the proper motor operation.
17,122
they have chain tensioners on the left and right of the chainring.
the one above the chainring is for the benefit of the motor.
Yours is shared between motor and chainring,
Plus, their top chain tensioner has a retainer to keep the chain away from the ring.
Laser Man
200
127
Michelmersh SO51
In the old days choosing a kit was complicated as you had to asses power/hill climbing ability, battery life etc. etc.
Much easier now - just count up the chain tensioners and if its got lots then you are onto a winner.
21
We also have the two chain tensioners. We don't have the one at the top because we never had a problem during our testing. Please consider that chainring and chain are moving in sync, so even if the touch each other after a big jump, nothing happens.
21
I'm attaching here the mounting plates for the four different mounting options. If you print in 1:1 scale the drawings, you can verify whether they fit on your frames. You can verify the scale by measuring the scale on the printed drawing.
Please let me know if those are easy to use.
Thanks,
Matteo
