Help! Need a compatible controller
2,807
Thanks again did strip it down, didn’t see anything major but remember the front top being taped up, here are some pictures, and maybe worth a risk to see if this fixes all the other issues, thanks again for all your help.
Are you eyes that bad that you can't see that the third photo is completely blurred? What are we supposed to do with it?
John Blower
20
Thanks again didn’t realise that picture was so bad, it’s just a picture of the display in one piece, not that I have had much help with my question re the display causing my issues? Is there anyone on this forum who could point me in the right direction please.
thelarkbox
944
292
oxon
You already have the best fault analyst and remedy repository probably available on the site on your case (not me).... its a process, and the info your providing is limited at best.. tho im no photographer either ;) since the display will invariably hold the settings applied by yourself and provide these to the controller box on system startup, if it has an issue it can throw a proverbial spanner in the works from the get go..
John Blower
20
Thanks for your help, I will get a new display and try, sorry I don’t know much about these e-bikes, but I am learning all the time, enjoy your week and thanks again
John Blower
20
Hello again managed to source a new display, but only stays on for about 30 seconds, do I need any special instructions for setting up? Or is there another issue, the motor kicks in when I turn the pedal, any help will be appreciated, regards John
2,807
Do you know which version you have, CAN or UART?
the next thing to figure out is whether it's the battery that shuts it off or whether it shutting itself off. You need to put a voltmeter on the battery to see what happens to the voltage when the LCD shuts down. If it holds steady, it's the LCD. If it collapses, it's the battery.
John Blower
20
do not understand CAN or UART?
I have to unplug it to get the screen back on, then it shows all the symbols then goes to just the mph/img screen, I think I need some code, will try the battery voltage, but it does come back on every time I re plug it in? Cheers John
2,807
CAN and UART are two different communication protocols. The controller needs the same one as the LCD, like people talking in different languages and they can't understand each other.
John Blower
20
Thanks should the display suppliers know what their item is, either CAN or UART, or can I easily find out this information, kind regards John.
2,807
It depends on the seller. Some mention it in the listing. Some haven't a clue what they're selling, and everything in between.
John Blower
20
Just found that the new display is showing an error code 30H which means a communication error, obviously the wrong display for the bike, any ideas I will post pictures showing the old display and the new one, maybe just give up and scrap the bike, here are the pictures
2,807
Not necessarily; however communication error is difficult to track doen because of it can have many causes. Things to check are the main cable from the controller damaged or squished by cable-ties. Check that you have 5v on any connector that you can get to that should have it: motor halls, throttle, PAS or brake. Your symptoms keep changing, so it must be an intermittent connection or short somewhere.
John Blower
20
Confused as someone else mentioned that it could be be how it communicates CAN or UART, so could this display be compatible? Thanks for your time with this
2,807
It might be, but you can't test that, so eliminate everything else first. You could also look at the battery connector. If it only has 2 wires, it's unlikely that you have CAN.
John Blower
20
Thanks again checked all cables and connections and all seem to be okay, couldn’t find a connection with 5 volts on, should I be looking for a UART display? Thanks again for your help
2,807
Did you check the number of wires on the battery connector?
