Zhelion
18
I want to mount only one wheel with motor, that is, the wheel would already have the motor built. I don't know if this is complex, but it seems like it's easy to watch a YouTube video, right?
Reactions: Pedaluma
Zhelion
18
I have heard in a video that geared hubs have a problem with the gears, and that is that many are made of nylon or something like that and they break down after 1000 kilometers and many manufacturers do not even put lubricant on them. This is true?
I have also heard that direct hubs are much better because they do not have a gearbox and there is no risk of damage to the hubs.
Pedaluma
30
It is very easy. Watch a few videos. I like to tuck the extra wires in a sack under the downtube with the controller on hub drive bikes. See photo with black sack. A front wheel is easiest but you suffer handling issues and torque steer. A rear is also easy, use twin torque arms - sold separately.
3,993
Completely false. Bafang used to test their geared motors to 30,000km. That was before they improved the material that the gears are made of. Even before that, many of the failed gears were in motors full of rust. 12 years ago, rusty motors and motors with failed hall sensors due to water getting in were very common, but failures of geared hub-motors today are extremely rare.
Most direct drive motors are useless for typical UK riding.
3,993
Don't listen to this guy. He has no idea of the type of hub-motor systems we use. Most of his advice is completely bogus. Go to Halfords and look at all the bikes with hub-motors. I'll give you £1 for every torque arm you can count that's on any of their bikes.
Pedaluma
30
Geared hubs are much better!
My problem with them is that I have two that I cannot get rid of. As soon as someone rides an optimized mid-drive they turn up their noses at the hub-drives. No one wants hub-drives. Any ideas of how to dispose of these? Is it ethical to donate them to Africa?
3,993
There are plenty of people on this forum that would take them from you for the cost of postage. Which exact motors are they? Can you show some photos if you're not sure which ones they are?
Reactions: Pedaluma
Zhelion
18
Ok I think I already have a slight idea of what I need to buy. A 250W 48V rear hub with a 17.5Ah Panasonic or Samsung battery (good brands right?) And a controller of ...? Could it be 20Ah or should it also be 17.5Ah?
Benjahmin
2,599
1,755
70
West Wales
You're confusing Ah (which is a capacity rating) with A which is a flow rating.
Ah = Amp hours. Tells you how much current a battery can deliver and for how long. So a 17.5 Ah battery will (theoretically) deliver 17.5 amps for one hour or 1 amp for 17.5 hours.
A = Current flow measured in Amps. A 20 A controller will have a maximum current flow of 20 A. In practice this will only happen in maximum setting and/or at times of maximum load. ie hill starts.
If you multiply Ah by battery voltage you get Watt hours (Wh) which is, perhaps, a more useful expression of battery capacity.
So a 17.5Ah 36v battery is (nominaly) 630Wh. A rule of thumb is that riders use between 10 and 20 Wh/mile. As a deliveroo rider I imagine you are quite fit so will be at the low side of this, maybe even achieving 7-8 Wh/mile.
But lets say 10Wh/mile. This would give you a theoretical range of 63 mile on a 17.5Ah battery. This would be affected by traffic (stop/starts), hills, weight carried, wind etc etc.
So a 20A controller on a 17.5Ah battery is fine .
Do look at the max current capacity that the battery is capable of delivering. Ideally this figure should be 1.5 times the max current of the controller so as to extend the life of the battery cells.
Zhelion
18
This has been a master class! Thank you very much.
So in the case of a 17.5Ah 48V battery it could also have a 17.5A driver right?
3,993
There's no relationship between the two. best would be to show us what controller, motor and battery you have in mind, then tell us what you expect/hope they will do for you, so that we can advise you exactly what you need.
Zhelion
18
I'm thinking to buy this: SWX02 48V 250W Rear Hub Kit with Lishui 48V 17Amps sine-wave controller.
And I'm looking any battery for a long distance.
Reactions: PC2017
Pedaluma
30
Forgive me, it has been awhile since I looked at these.
The 26in clincher front hub is Non-Geared and 750W with a throttle display and is 48/52V. It has brake cut-outs levers and a 20A controller, branded Voilamart. The 29er is perfect. I paid $440US for it with shipping. It is a Internally Geared, a CSC, Carbon Speed Cycle brand and is 36V with 350W. It has an attached 160 disc and 9-Speed freewheel of Nickle plated gears. It also has a throttle with display and a 20A controller with cut-out brake levers.
I do not ship stuff. I work on bikes locally like a dog walker or baby sitter, I am a local bike mechanic who works on bikes I can touch. If you care to see what I am working on these days go to https://pedaluma.com/. Again, I do not ship or sell on the internet. An Africa Project donation may be the best option. But is it ethical, given that hub motors lag, lurch and underperform? I like clean builds.
Reactions: Zhelion
D C
1,142
577
Those are very elegant bikes, personally I never understand why folk get an electric bike then try to pretend it isn't, maybe some deep seated guilt feelings or being scared of being called a cheat!
You've done some nice looking work.
Reactions: Pedaluma
Zhelion
18
Thank you but I want any legal kit for my bike.
I have been looking at the voilemart brand a lot but they told me that it is not a recommended brand, that it tends to fail. Is true?
3,993
So, you bought the cheapest hub-motor kit with the crappiest controller that doesn't even have a torque sensor, then you condemn all hub-motor sytems? Brilliant!
Reactions: Pedaluma and POLLY
Pedaluma
30
Thank you. Isn't it great to have diversity, options and different tastes, just as with music and food.
Reactions: Zhelion
Pedaluma
30
I likely did on both counts. Guilty as charged. Most of my (Covid safe) riding mates have commercial rear hub builds and we are friends. My friend Fritz is upgrading to one of these this week:
