Hi, As promised a review/guide to my bike.
It is a Scott p2. 9speed cassette. Nice bike well made. Ive been ridinding it for about year to work 14 mile round trip. My previous bike was carrera subway 2 it lasted about 4 years of daily commutes befor the frame snapped.
Electric kit and wheel, battery supplied by BMSBattery (China).
500w rear wheel drive, 48v10ah, and a 500w 30a controller. (no instructions).
Check the wheel for loose spoke be for you fit and after you done a few mile, mine were really loose!
The customs and excise didnt seem that interested in the box or its contents. DHL shipping is a must and is absolutly awesome, shipping in 3 days door to door. The packing notes said sample bike parts value $37.00 ..
It has taken probably 3 months or so to gather together all the bits n bobs + order the kit etc from china.
I also bought a fitting kit from frank.
As well at the kit you will need switches, wire and a little common sense.
My advice to you is:
If you are wanting to convert 9 speed don't bother with the 9 speed freewheel just go with the standard 7 speed, its alot less hassel and dont look stupid when you wheels dont line up etc and you wont have to stretch your forks.
You will need to get a bush to fit inside the freewheel or a nut? .. I used a bushing from franks kit.
I have used the standard torque washer thingys that came with the kit, I have made some torque washer things so if I need them i can fit in the future. At the moment the axel is a nice tight fit in the dropouts and looks pretty solid. I didnt use franks torque bits as the were not a good fit on the axel ..
The battery bag was a big problem, The Battery is 35cm long I wanted a nice tidy topeak mtx trunk bag which was supposed to be 36cm long but when it arrive it measured 31cm .. go figure .. Then I ordered a topeak dry bag which was supposed 38cm long ... that turned out to be 31cm too .. someone needs to teach topeak how to use a ruler.
I ended up in "go outdoors" on friday and found a bag that fitted the bill quite nicely. Just cut the plastic rings holding the shoulder straps then use zip ties to fasten to carrier.
Heres some photos
The bike goes very well 29mph on flat no pedeling goes up hills like they ain't there. I've probably done around 20 miles or so on it now .. I just love it ..
Not the cheapest way to build a bike but not as expensive as a lot of others.
Riche
Heres some photos
Riche
