motor problem
8,844
If you have the learn wires (intellegent wires) the controller will find the correct sync combo for you.
Carry out the learn process then when working correctly turn of the bike and disconnect the wires, sometimes it may take a few attempts for the learn process to work. Each time one has to turn off and try again, once working correctly if the learns wires are left connected it will try all over again the process.
gazza19
218
thank you i will try that and let you know the results
gazza19
218
Thank you all for your help the bike is up and running now. Onto next project I’m converting another fold up bike it’s got a 36v 350w motor and it came with this controller the wires I’m holding in pic are for the lcd which I havnt got is there anyway of bypassing the lcd also can anyone tell me what the purple wire is for I’m hoping to convert the bike in the picture would I also need to put electric brakes on it or could I leave the original ones on as usual thanks for any advice given
8,844
Purple might be bike lock wire, hence someone has tagged a bit of Red to indicate live 5v.
8,844
I don't know if these work the same way, with the KT you can omit the display for a one PAS level control. With the KT one links together Gnd/Black to Yellow and Red to Blue.
The worst that can happen is you fry the old controller, so nothing lost. If it doesn't work buy another Brainpower or opt for the nicer KT stuff.
gazza19
218
would this do i also need the nine pin motor extention cable for it do you think the 60cm one will do https://www.amazon.co.uk/Starbun-Electric-Motor-Controller-Brushless/dp/B07WZZR19G/ref=sr_1_3?crid=LXFVVUKR4D5H&dchild=1&keywords=brain+power+electric+bike+motor+controller+model+sl-qx041kz&qid=1635172056&qsid=258-1189035-3831531&sprefix=brainpower+electric+bike+motor+controller+model+sl-qx041kz,aps,102&sr=8-3&sres=B07WZZR19G,B07Y9CZ9T3,B07DB6Z3LK,B08FQMNQ9P,B07WDG27F6,B07W5Z1VK2,B08HV6664Z,B07J6FZXHX,B0768S1TB8,B07FKQQDCD,B08Q83313Y,B07GK3LR73,B07ZZCGGJJ,B08G1PXTF2,B08G1PCZXW,B08ZNKYGBW
8,844
It appears to not use a display so will work, how well it works I wouldn't know.
It has PAS so will only have one level of power with a throttle for max power .
8,844
For ultimate control it is simply best to fit a KT with 5 PAS levels of control , then one is spoilt for choice for power levels but always in control of them.
Reactions: gazza19
8,844
