Motor connector
gazza19
218
Hi what’s the easiest way to disconnect this connector without breaking it or the wire it’s stuck and hard to separate any help would be appreciated
matthewslack
1,845
1,334
The metal bit is probably a retaining nut, so it will probably unscrew, and then it will pull apart as normal.
Reactions: danielrlee
3,192
Looks like a multi-pin audio connector with the knurled nut/collar held captive by one end, and threaded on the other. Seems crazy to use one (if an audio connector has been repurposed) on a bike if the steel used isn't stainless. I'd turn the nut both ways by hand till it moves in one direction or other. WD40 would be a bad idea judging by a report of it being electrically conductive on this forum, some time ago - some dude squirted battery pins with WD40 as I recall, and there was a short.
3,192
If your bike working ok? Why do you want to disconnect? I'm sure someone will turn up with a better idea: A heat/cool cycle could break up the rust: alternate hair dryer and a bag of frozen peas, try separating every time (pushing, as well as trying to pull apart). If that didn't work... swiching off and removing the battery first, I'd apply a drop or two of 99.99% isopropyl alcohol, dissolves rust. Bear in mind it also damages rubber. The collar should loosen after a time and with movement, but if it doesn't, I'd heat up the connector with a hairdryer and try again, then cool and try again. If it still refused to separate, I'd make sure to dry off the remaining 0.01% electrically conductive water before using the ebike.
https://www.ebay.co.uk/sch/i.html?kw=99.99%25+isopropyl+alcohol&toolid=20004&LH_BIN=1&_sop=15
