Hi
looking for some advise on a bit of mix match kits that I have left over .
I am converting a classic Giant road bike test stage photo attached.
I have a new 250W YOSE motor that I know works as t will work with the YOSE controller.
But I have a KT Controller and the KT LCD 4 from Top bike.
The Battery is Yose 36v Frog type 10 AH
The pas is one of the YOSE ones photos attached.
kT thumb throttle.
I have it sort of working ie it turned the motor but some thing is wrong it’s making a strange noise sort of strained and not full power .
I have been looking at the advanced settings in the KT screen but do not understand fully what they all do .
But the main question on here is is this set up going to be compatible by fine tuning in the settings.
Second option without buying the YOSE bits that are missing is I bought a brand new G Tech motor and rim on e bay because it was vey cheap at 50 quid it’s the one in the photoI am just about to see what happens with the GTech one same set up any thoughts on if this will work or not ?
CHEERS
BAZ
kT thumb throttle.
CHEERS
BAZ
