Ah OK you are going for 74v. I'm running 48v so easier to handle. With those sealed parallel packs you cant get to the individual cell so you won't know if one is weak. BTW sometimes these packs come out of the factory with a weak cell so I think its important to be able to monitor individual cells, I would have gone for individual cell packs.
You only need a balance system using the Meanwells, they are CC/CV...the current tapers near end of charge, so set PSU votlage to equal overall pack voltage at full charge and balance out at end of charge. The balance system does not need to remain connected just the LVC scheme, I disconnect the BM6 boards and plug in the Battery Medics. The Medics are set to discharge the cell at anything over 4.1v.....so if a cell is slow to reach full charge the Medic holds back the other cells in the pack until it cathes up.
I understand the frustration in trying to get started but with Lipo I think its important to know what you are doing and try to get it right to start with, if it where A123 cells I would not be concerned....
Anyhow good luck, please post on how you get on.
