I am sure others have used these programmable controllers before and I know there have been previous posts about them, but this is a first time for me even though I have been messing around with ebikes since 2009.
I guess I have always been a little cheap and had assumed that all controllers were similar/the same and usually just purchased a stock controller with whatever motor I was getting. Most of these stock controller are about 1/3 the cost of the likes of these programmable Lyen controllers.
Well as they say you are never too old to learn something new
My Lyen Controller turned up yesterday. I am now beginning to realise the benefit of these more expensive controllers. Ed Lyen is a very helpfull chap responding promptly and courteously to the many emails I have sent him
The challenge I was having was with one of the new Tongxin Goldant motors in that their controller was setup for pedelec only. This meant that that I needed both an ebrake and a cutoff switch to tame it properly. Not sure if it is the same with all pedelec systems, but this one seems to always ramp up to full speed when you are pedaling and give over run when you stop. Also if you stop pedaling for a short time then the motor cut out when I often just need a little throttle to keep momentum going.
Anyway the controller I have received has all the bells and whistles for me to play with ebrakes, PAS, Throttle, Cruise Control, Three Speed setting switch on BOTH PAS and Throttle and of course all the leads and module to program it. I am looking forward to mixing and matching these to experiment.
That said my main requirement was a replacement for the Goldant controller that had a smooth throttle response. This controller met that requirement exactly.
The initial challenge I had was that the power connector has "two" +ve connectors that both have to be connected. At first I thought it was faulty as there was no power in the throttle circuit when I connected up power to the main two power leads. The second one apparently switches on the controller. I read that this only has to be initially made and had assumed that once done it could be disconnected and still work. Seems that it has to be connected permanently.
So why have a a second +ve connection ?
This is the connector that has a second smaller +ve lead on the top pin ?
I am also struggling with installing the programmable software on my Win7 64bit machine.
Regards
Jerry
Regards
Jerry
