Help! Looking for a lightweight and compact conversion kit
Katrina
19
I fitted one to a Dahon Jetstream 8, which has quite a stiff rear subframe. As I said, you have to dish the wheel quite a lot, which is why I'd recommend the freewheel version and 7-speed gears. 7-speed gears are very cheap if you want to change from anything higher.
Bikes are so complicated:eek:
Reactions: RogerA
harrys
417
113
Chicago, USA
Also consider the Q100H. Freewheel version. Fits 135 OLD and will go down to 128mm if you change the spacers and use a 5/6 speed freewheel,
