LCD S866 - not working - error E10?
8,718
Buy/use another opposing 9pin connector and use the wire tails for testing with, better still place the wires tails in to a wire connector strip to prevent shorting and use the opposite side for probing.
Reactions: laurent1784
laurent1784
12
40
Panama
Hi everyone. Just wanted to thank you for the help. Managed to get the swagtron working again. Issue was the display. Problem is that the en06 display and controller these bikes use are customized. This is why I couldn't get any other screen to work with the controller. Luckily, found an ebay seller who has surplus parts from the brand since they went out of business. If you try to access the display menu options, you can only dim the screen and change units from miles to km. Nothing else since it is blocked.
