LCD S866 + Brainpower controller
3,994
Yeah, I believe it is a 12 magnet one.
The 12 magnet discs often give problems. I've solved it before by pressing out every second magnet to convert it to a 6 magnet disc. The number of magnets doesn't make any noticeable difference in response or performance.
Freskas
16
Spain
I am trying to find a manual for this LCD which I bought together with the Brainpower controller. I have the bike running but the speedo only works when the motor is running which is probably due to having no white wire from the hall sensor, I could fit a wheel sensor and connect to the controller but I guess I would have to disable the existing speed read out. I have also found that when I plug anything into the lamp output on the controller I get an error code 8 or 10. Here is what I have on the LCD menu some of which I have worked out:
P01 - 001 to 003 Screen Brightness
P02 – Miles or Kms
P03 - Volts 24/36/48
P04 - Speed Limit
P05 - 0001 or 0002 PAS Level Start up
P06 - Wheel Size
P07 - 0 to 100 ?
P08 - 0 to 100 ?
P09 - 0000 or 0001 Non zero start
P10 – PAS THR or Both
P11 - 1 to 24 ?
P12 - 0 to 5 ?
P13 - 5 to 12 Magnets on PAS ?
P14 – 1 to 20 ?
P15 - 000.0 to 200.0 goes back to 029.0 when motor is used
P16 - 000001 Mile – Cant change this one
P17 - 0001 or 0002 ?
P18 - 50 to 150 ?
P19 - 0001 or 0002
P2 – Backlight on off or switched.
Hello
Freskas
16
Spain
Hello I am just new on this forum . A few weeks reading you and found it really helpful . I am trying to change controller and display on my black pack booster bike, just five wires from the hub. Mi problem is that as soon the display gets on the hub starts turning . I just connected the 3 power wires ,+ and - the five wires from hub and the display 5 small wires .... any help thanks a lot from Spain
3,994
You need to disconnect the self-learning wires shown in the diagram. The motor turning is what happens when it does the self-learning.
Freskas
16
Spain
Ok thank you I will try later and let you know what happens
No luck ... I think I don’t get the right parameters into the P numbers .... does anybody know the right parameters forces 24volts motor ?? Can get running by pedaling ... thank you
Freskas
16
Spain
I disconnected the green cable and it’s stopped turning as you suggested. But no way to make it work by pedaling ..
Reactions: MattyK
3,994
Without looking at the manual, I'd say that P7 is for the speed sensor to make the LCD show the speed correctly. It should be 1 or 6 normally. What are you using for a speed sensor?
Freskas
16
Spain
Black together on both sensor and controller red the same and yellow on sensor with blue on controller
Freskas
16
Spain
I am about giving mi up!!! The sensor worked with another controller . Almost sure are wrong parameters ....b
