The Ezee ones will be perfect, and you can get them quickly. Don't use the jubilee clips to hold them though. You need the tie-bar to be properly anchored. Make your own tie-bar if you have to. You only need to drill two holes in a piece of mild steel. Like this on the brake side, but you'll have to use a bit of imagination on the other side:Couple of torque arms required I think. Are the Cycleeze still the ones to go for?
