KUDOS ‘IBEX’ CRANK DRIVE BIKE
• Frame 6061-T6 aluminium, 46cm
• Forks SR Suntour F12-XCT-V3-26
• Shift Shimano SL-M430 Alivio 9-speed
• R. Derailleur Shimano SL-M430
• Crank 48T
• BB B-902
• Gears Shimano CS-HG50-9,11-32T
• Chain KMC Z99
• Pedals Wellgo M21
• Front hub Quando alloy QR 32h
• Motor 250W crank drive (centre motor), 6oNm
• Rims Double wall 32h
• Tyres Kenda K885 26" x 2.0”
• Stem 3D forged 6061 aluminium
• Handlebars Alloy 620mm
• Brakes Tektro Auriga E-comp hydraulic disc
• Seat Vader 1134A-04
• Seat post Alloy w/clamp 030.4 400mm SP222
• Battery Li-on 36V x 10.4Ah Samsung LiMnO4
• Throttle Thumb throttle
• Max. speed up to 25km/h
• Range up to PAS 60km
• Charge time 5-6 hours
• Weight 21kg
• Standard EN15194
£1295.00 inc VAT
As requested, please find draft details and photos of the new Kudos crank drive bike.
The specification is still subject to minor revisions but should be mostly correct.
The frame has been purposely designed with a long top tube and long seat post so, despite the 46cm seat post dimension, it should accommodate a wide range of rider heights.
The motor is a joint development between Kudos, our manufacturer and a university, it has been subject to extensive quality and durability testing, including –
1 5,000km road testing – smooth road, Belgian pave, washboard, sand, sine wave and ramping
2 10,000km equivalent bench test at 20kmh x 500 hours
3 Peak torque test – 10,000 times start under peak torque
4 Dust and water test to level IP54, 2 hours duration
5 Simulated max pedal pressure test, 100,000 times assuming 150kg rider
Motor specification
36v
250 watt
Steel gears
90rpm max speed
60 Nm peak torque
4.5kg weight
48T chainwheel
We have had an extensive testing session between the Arriba, Tornado and Ibex bikes. They each have their own strength and weaknesses.
The Arriba bike with its torque sensor faithfully replicates the input power of the rider. The Ibex (crank drive) is very smooth and readily freewheels, it is effortless up steep hills. The Tornado is just plain fast.
Would welcome any local Pedelec member to come down and test these bikes.
Dave
Kudos Cycles
