KT sine wave controller- how to make unrestricted??
3,993
would it help if I bought a new lcd display
No.
Let's take a step back. Please describe your exact problem. if it's that the display sitches off, there can be lots of different reasons. Please give details of the circumstances in which it goes off. is it when you're parked up, goimg up a hill, after you've done 5 miles or what? The more you give, the quicker we'll solve it. Try not to give irrelevant info though.
lata94
14
No.
the problem is that I would like to drive about 25-30 kilometers per hour instead of 16 km. the manufacturer has lock almost all settings?
lata94
14
No.
lata94
14
How did you come to that conclusion? Do you see an unchangeable 16km/hr in the max speed setting?
yes i think they have locked the display from the factory. I can neither turn up nor down from 16 km. the same is with wheel size it they have also locked
3,993
It what you're saying is correct and you can't adjust it by the method explained in the manual, then you have a special software version, so you'd have to get a new LCD to unlock it.
Which LCD do you have?
lata94
14
I have a KT-LCD3
8,685
The electronics are customer custom ones that KT offer to third party sellers, your issue might not only be a LCD but also programming within the controller.
If it were I would buy the pair from the same non oem seller.
lata94
14
thanks for helping. do you know where to buy it?
8,685
From UK vendors expect to pay about double the cost of buying direct from China.
Buy lcd and controller from the same vendor to be 100% sure of connector compatibility.
For UK ebay etc, or forum user Daniel has a online presence at Torquetech.co.uk.
Other wise we use Aliexpress sellers, Topbikekit, Greenbikekit in China. PSWpower and BMS battery are two others.
What you don't know is, is it the lcd or controller programming preventing the changes.
Reactions: Slightlypedantic
lata94
14
okay thanks for your help again.
I might ask a little silly but would not it be cheaper to try with a new display first
8,685
No reason why not and if it is still the same, you know it is the controller programming.
lata94
14
now I have talked to a company where I have agreed that we will test with a new display.
will return once I have tried it.
if it's the controller that's teasing, can you reprogram it?
Megadevs
10
Hi everyone,
I have the same issue. Klaxon restricted wheelchair attachment restricted to 16kph. The max speed setting is locked by the manufacturer.
I see people have tried replacing the LCD3. Did this work?
