Help! KT LCD3 eBike display "info 03" error
PC2017
1,334
338
Scunthorpe
the mxus hub motor has a 3 plug special tool (or make one) to split the motor in two
How many miles you done before it died? And well spotted on the screw plate, this would be the motor I am looking at for my new build, that said they may have changed the design since yours.
mxer
92
10
The motor didn't die I found out it fell over in the bike sheds at work a colleague picked it up for me, ride home was peddle job the motor is great! Except you can't get into it!!..which I will look out for in the future as would be nice to have the option to replace the gears and clutch! But tbh these motors outstrip the battery controller and the bike for ware so not to worried lol
Reactions: PC2017
Kesta
Apr 17, 2022
Hello I am on my second 1500w electric bike conversion and I did not know this forum. I had the same problem of "03 info" on the screen and the axle turned in the fork. The motor cable wrapped around the nut but everything was still working, then we saw that during the test run some of the cables were stripped, but not severed. How to fix them? With solder? Pictures coming soon, thank you!
8,781
The halls will be fried so the need replacing, one need to open the motor and pull the motor apart. Whilst at it the motor cable needs replacing to be honest.
Reactions: Kesta
PC2017
1,334
338
Scunthorpe
Reactions: Kesta
8,781
Billyboya managed it on his scooter, it is a faff but doable with patience.
Reactions: PC2017
