KT controller
8,616
A good example of a very good hub which I use for my Roadrat and towing a laden trailer (up to 90kg) is the Bafang G370, it has a fairly high two step gear ratio and is 36v 201rpm rated so about 16/16.5mph at 700c.
I run it at both 36 & 44v but not for the speed but the unpowered ability, I have intentionally set the cut off low at 13.2mph just to get me going and then without too much effort rides nicely to 20 mph unde rmy own power (without a trailer). For towing slow I'm happy with for stability esp some of my precious cargo.
PC2017
1,329
336
Scunthorpe
My YOSE is circa 220rpm based on the sales pitch of 36v with that extra 30% on 48v I get 280ish rpm and better mph plus no issues up hills however I keep my amp to 14 or 15 if I swap out a controller, but my 14a has served me well & if I was to put my 17a on I would reduce that to 15/14. Now when that dies I'll use my new mxus but that rpm is 270 @36v so circa 330rpm on 48v but keeping my amps low should prevent/minimise overheating when up hills, but gain a mph or two. Any problems on 48v and I stick to 36v or amp reduce to 12/13
