Joycube JCEB360-11 battery
8,789
The only way of knowing if a cell group hits HVC before any others is to charge as far as poss then open the battery to get all 10 cell group voltages to see if a problem does lay there.
8,789
It looks then that the BMS has a 4.15v balance set for each cell group, so all looks/appears to be fine then. The manufacturer possibly looking at slightly longer cell longevity by not taking the charge to the max, the mah capacity lost is small and will be less then 100 mah one would expect.
Tazmantic
50
7
52
oxfordshire
Thanks so not to worry about the 5th led on the test button then though I’m sure it used to light, will have to see what happens after I’ve started using it again.
but one thing I’ve noticed as it’s 36v should it not have 10 cell groups (10s) and thus should there not be 11 wires on the balance plug mine only has 9 wires??
cheers
8,789
Most BMS have the same number wires as cells or +1 for the B0/B-, somewhere along the line the BMS is sensing the last cell group I assume from another port on the BMS ?
Reactions: Tazmantic
3,994
cheers
You should always measure the cell voltages from the common ground. That will tell you where your missing voltage is.
Tazmantic
50
7
52
oxfordshire
Measured cells again and each group is 4.15v and from the ground to each group the voltage rises by 4.15v (8.3v, 12.45v, 16.6v etc) till I get to the last set and 41.5v so its looking like the charger will only charge to 41.5v.
8,789
The BMS dictates the final balance charge in most batteries, I have an LG BMS that balances to 4.15v per cell it is nothing to be concerned about.
