It's a long way home with no power.
M
mk1
Electric bikes seem like a great idea, but what happens when your batteries go flat or your electrics fail miles from home:( . The lighter bikes I guess would not be too much of a problem to get home, but some of the behemoths with sla batteries and full suspension I think would be a nightmare:eek:
Does anyone have experience of this?.
Martin
frank9755
1,228
London
It's rarely happened to me as, if in doubt, I carry a spare battery. But my experience is that running out is fine as long as you have the right gears for the terrain. Then its very like riding a normal bike.
It happened to me a couple of times with my old Powabyke, when I went on long rides (c.40 miles). The Powabyke had 21 gears. At least 17 of which you only ever use with a flat battery! I just rode it home in a lower gear. As a steel framed bike it isn't bad to ride, and the old brushed motor doesn't give much cogging resistance. One time was in a hilly part of Wales and I got up a couple of steep ones using the bottom 'megarange' gear. On the flat the weight isn't a factor.
On my wife's Powacycle I had it once. There aren't so many gears, but it is ok to ride unpowered too. A little bit more resistance than the Powabyke but I got home fine.
My Wisper has an enormous battery that I've not got near to running down but I've ridden it unpowered for stretches, to see what its like. Again its fine. Perfectlyy rideable but slightly heavy and high geared.
If you get a Panasonic-powered bike (eg Lafree/Gazelle/Agattu), riding with no battery, you are riding a normal bike!
Frank
M
mk1
Frank
Thanks Frank.
So without wishing to open a can of worms. I realise the Panasonic system has the least amount of drag, but of the hub motors which would you say was best with the power off.
ps How do I just show a small section of quote, rather than the whole thing?
Martin
30,652
Just delete the words you don't want after raising the quote Martin.
Direct drive motors have the least drag usually, since they have no orbital gears to be turned. Most geared hub motors have freewheels disconnecting the motor itself, but the orbital gears are still connected to the hub shell and turn when cycling only, so there's some drag.
Personally I hate pedalling geared hub motor bikes without power, but that's probably because I've always lived in a very hilly area where the extra bit of drag is the proverbial last straw.
coops
1,225
Manchester U.K.
Hi Martin :)
Thanks Frank.
Martin
Easiest one first ;) - to cut unwanted text when quoting, simply delete what you don't want from between the {QUOTE} and {/QUOTE} markers (for { } read [ ] :)) when typing your reply: only what you leave there will be quoted :).
Your other question would be better answered by someone with more experience of different bikes than me, but in short there can be quite a difference between bikes & motors in that respect. I find my Torq (brushless, geared motor) to be acceptable as fairly 'minimum' drag when freewheeling or riding with power off, given that the internal gearing cogs are always engaged, whereas I found noticeably more retardation freewheeling downhill on an Ezee Liv (brushed motor) for instance, and maybe even the Ezee Cadence (same motor as Ezee Sprint I think).
If you see the nano motor/tongxin threads, that motor apparently has quite low freewheel drag (no cog gears), but can slip in high torque situations. The Giant Suede & Twist 2 motor doesn't have a freewheel to isolate the motor so is harder to pedal unpowered, from what I hear, and I recall a member saying some of the Synergie bikes had very apparent drag when freewheeling.
So maybe the best thing is to try some out if you can and hopefully other members will have more experience on other bikes to comment on this :). Also, best try to find a bike thats reliable, electrics & parts-wise, and with sufficient range to get you home, to avoid the situation if possible :) or just get one which rides like a bike unpowered i.e. a panasonic! They seem likely to be very reliable too.
In the context of your original question though, I agree with Frank's post and although I'd rather be riding a panasonic if my battery was flat, I've ridden the Torq ok in that way, though much depends on rider fitness and gearing (my Torq has modified & rather lower gearing than the original standard) and terrain - my area is much flatter than flecc's, so not so much the last straw here!
Stuart.
frank9755
1,228
London
In running through what the electric bikes I do/have owned are like without power, I actually forgot to mention the one I have with a Tongxin motor!
It has no noticeable resistance and I ride it as a normal bike.
Frank
Footie
549
10
Cornwall. PL27
Electric bikes seem like a great idea, but what happens when your batteries go flat .... some of the behemoths with sla batteries and full suspension I think would be a nightmare
I have ridden my sla mountain bike without power and I think I could make it home.
As a point of interest - It would appear (as I have just discovered) my sla mountain bike produces a "regeneration current" when the power is turned off - sends charge back to the battery :)
So if mine goes flat and I have enough leg power I could find a nice flat road (bit hard in Cornwall as it's all hills) and cycle up and down to recharge my battery - in theory :rolleyes:
keithhazel
997
dont think i want to ride my Quando home without power,like a "normal bike" is not the phrase i would use when it has or hasnt got power...its a smart wheel barrow with a motor, great when you got a motor but not the easiest push without...have i summed it up how you would put it Flecc ???..or are you just fitter then me..lol...
30,652
No, that's a fair summing up Keith. I once ran out of power only a couple of hundred yards from home, most of that being 2% up at most, but trying to get it to 10 mph was a huge struggle! And as for the final 14%, I pushed it up there.
Yet the wheel spins very freely by hand, and it's the motor the Torq uses anyway. Much of the difficulty is due to other factors in the design, it's more an electric bike, rather than an electric assist bike, as I know you'll understand from your own experience.
keithhazel
997
however for saying this one thing, or should i say yet ANOTHER thing im really pleased about my Quando is when im approaching a junction or anywhere for that matter and cut the power it still free rolls very well, much better then pedleing alone, my other bike used to drag a lot as soon as power was off, but this was a much pleaseing aspect,i like to be under non power and in comtrol as i approach a stop...as soon as i pluck up courage or leg power im going to take it on a purely peddle assist run and see how far i can get..im guessing as 22 on power alone i might just be able to get around 30-35 ??? :) on pedle assist.
30,652
If you last that long Keith! It's a tough call on a Quando, as you'll either be riding slowly for three hours or spinning like mad for two hours.
Unless you have a 30 mile long downhill stretch. :)
coops
1,225
Manchester U.K.
I suppose a major limiting factor in terms of range & pedal assist for the Quando is its single 58" gear, especially in hills, hence the Q-bike :D, but the motor freewheels relatively well as you say Keith and at least the motor is geared for hills in 20" wheels, if the gearset isn't :).
Its a good question though, about ease of riding without motor power, and one which doesn't seem immediately obvious (it wasn't to me!) when thinking about buying an electric bike, unless one is a regular cyclist or technically minded perhaps :).
In terms of the bike weight question in your original query Martin, it surprised me just how much heavier a 35-40kg steel-framed & lead-acid battery bike felt & handled compared to a 25kg alloy framed & NiMH/lithium battery bike, and there is always a penalty on hills too: even 25kg is heavy compared to a modern lightweight bike & I don't think I'd be happy or comfortable to ride anything heavier than that on a regular basis.
Stuart.
keithhazel
997
i went down this stretch of road on way home today, wasnt steep hills or anything like where you live but i soon got up to 18.5mph and was most pleased/rather nervous...happy on a stright bit but not round no bends at that speed, my new wider handle bars sure help but its no less scraey then a helter skelter on a folder, 15 seems to be going no where really fast but what a difference 3.5 mph makes..:eek:
MR E
58
West Sussex PO21
I don't think that a power or battery failure would be too much of a problem on my Torq Trekking , as I have tried cycling with no power recently , and there is minimal resistance , and it feels not a great difference from my ordinary bike but my concern would be to have a puncture a long way from home.( I guess it depends how far from home you are)
I have just taken off the back wheel and found that not only do I need a 15mm spanner for the wheel nuts but a 10mm for the brake cable bracket.
Good job that "puncture resistant " tyres are fitted.
Just bought a spare inner tube ---- just in case!!!!
Moral of the story --be prepared- always take a tool kit , perhaps not a spare battery-- too heavy!!!!!!!
Never was a boy scout though:p
30,652
And best have two 10 mm spanners David, I've found the bolt and but stubbornly turning together. Sounds like it's needs are the same as the Torq one's.
30,652
It's actually 69" Stuart, but still quite low for a single gear.
It started out in life as a 54" gear, but eZee soon corrected that, changing the 18 tooth freewheel for a 14 tooth BMX one.
coops
1,225
Manchester U.K.
I'm glad to hear you're having a good experience with the Torq Trekking David :).
Puncture risk is a concern to me too, the standard Kenda K-shield do offer good puncture protection: several Torq owners have now fitted highly puncture resistant marathon plus (schwalbe) tyres, usually size 700C x 38, to minimise the risk & inconvenience of flats far from base and for lower rolling resistance too: I was a bit nervous of making changes to my Torq at first, but it has been extremely rewarding and worthwhile, especially the throttle mod - at least you probably won't want to change the gearing on your Torq! ;)
There's a very old thread, pertaining to kit carried on the bike, wherein flecc listed his bike travel kit essentials, if its still in the forum archive, though it may be on his site if not?
Stuart.
Ian
1,333
Leicester LE4, UK.
An old fashioned puncture repair kit is a good thing to carry then most punctures can be repaired without removing the wheel. Last winter before fitting Shwalbe Marathon Plus tyres to my Torq I suffered a number of punctures in the puncture resistant Kendas, but as far as I remember I fixed all on the spot by simply slipping the tube out and patching while still on the bike. Locating the puncture without water can be tricky but usually not impossible.
I carry a spare tube and tools just in case though, the tools being a multi-tool with allen keys and screwdrivers, a small adjustable spanner plus a few latex gloves to keep my hands clean, spare fuses and a removable chain link.
I carry a spare battery on longer rides as well if I think range may become an issue.
fishingpaul
874
86
I had a sakura s300, which uses the same motor etc as the powabykes, and i often rode without power on flatter sections,it used to fly down hills with all that weight and virtually no drag from the motor,the fastest i have ever been on a bike.
