Thanks for this explaination Dave.Most motors and controllers have similar efficiencies, althought the efficiency of the motor varies a lot with speed, so, if you have a motor capable of 20mph and you ride around at 10mph, you'll probably be making as much heat as motion with your motor and that will compromise your range.
So what would happen if the motor is give 20mph max speed at 36V, and that you double the voltage (74V) in order to reach higher speed? Would I loose a lot on efficiency too?
