There are bike shops will fit a kit for you, and prices vary a lot but I don't expect it will be cheap. Probably at least £100..but maybe other members here know different. There are some specialist shops I expect or dealers who will do it for you, but you may have to make a trip there or else pay the courier both ways ontop.So do you have to fit it out yourself using a kit ? I'm interested in converting a bike to leave in Devon because the logistics of taking myself, my Agattu and the inevitable load of stuff up and down on the train = nigh on impossible proposition.
Fitting a kit is not really that difficult, especially if it's a front wheel conversion which is usually a piece of cake to do.. the rear wheel can be more tricky because you may have to completely replace the gears, depending on how many gears you got...rear motors in kit-form are normally limited to 6-spd or 7-spd freewheel gearing unless you buy and fit a heavier more expensive cassette compatible motor which would have to be custom spoked into a wheel rim.
