No need to disconnect wires, do the following:I have two volt Pulse bikes with the C1 display. From various bits of information I have found, including the link on the controller to disconnect which in itself has made no difference. I have got into menu three using the code 2962 but there are two other menus that the code does not work on. Anybody had any look yet?
Turn on bike
Hold up and down for 2 sec
When in menu up and down again
2962 is the password
Menu 6 - should say sys. Press mode
Press mode again until you see max speed and change, I’ve done 40
Then hold menu to go back to the main screen (the one you normally use when your riding)
Hold up and down again to get into the general menu.
Hold mode and down for 2 seconds to enter general settings
Password is 0512
Change your speed (LS) at which you want the motor to cut out. I’ve done 32 I think
