The calculation is right, but I'm not sure that you can trust the 300w rating. That might be the output power. Instead, you should look at the label to see what the input current is, then multiply that times 230 to get its consumption, then add, say 20% to that to include the inverter losses.
Don't forget that your lead battery only has about half the useful capacity stated, so 100Ah is actually 50Ah. Also, you can get substantial cable losses on the 12v side because of the high current, so keep cable length to an absolute minimum and as thick as possible.
