info required
billyboya
1,137
90
73
uk
Simply put 400 means 400wh or about 11ah capacity for a 36v battery.
4 levels of assist by way of the handle bar display, each level giving variable amounts of current/watts to the drive system. Eco is the low level of power through to Turbo which is the high level of power.
I know my 24v battery is 16Ah which I think means Amp Hours , so if it said 4Ah I will have used up 3/4 of battery.
2,835
Ah does indeed mean amp Hours, that makes your battery 384wH, a fairly reasonable size (better than most 24v bikes).
It's unusual for a display to show Ah, but if it does 4Ah would in simplest theory mean you had used 3/4 of battery. In practice you probably have a lot less than 1/4 left for a couple of reasons.
When the battery is full it will be at somewhere around 28 volts;
by the time it is getting to 1/4 it will only be at around 20v.
So using 3 amps at the start is giving you nearly 50% more power than using 3 amps at the end.
Also, as you use power from the battery the voltage drops still more (voltage sag), especially higher power.
If you stepped up to 15 amps the 20v could easily drop to 18v or even 16v.
That's pretty significant, and if the battery gets to too low a voltage it will cut out altogether to protect the battery from damage. That means that a battery with just a small amount of charge left can only deliver it pretty slowly. If you have a significant hill to climb it may cut out just when you need it most, just as you are tired and nearly home at the end of a long ride. (We are lucky from that point of view, we live near the bottom of a hill.)
I believe the basics of what I have said there are correct. Somebody else with more knowledge may be able to give more precise idea of the exact voltages. They vary from battery to battery. As a battery gets old the total Ah/Wh it can hold is much less than when it was new, and the drop at the lower end particularly severe.
8,774
Maths a bit out there 24v is usually 7s, fully charged is 29.4v. 28v is only 4v per cell group.
Also 20v is too low though most spec sheets use 2.8v as a minimum, with mine 22.4 - 23v is the lowest I go which is 3.2/3.28v per group.
The avatar bike is the 24v Swizzbee and I see 16a continuous and up to 34a at times, I use a 977wh batteries. 50 -60 miles is my range. It is capable at times of up to 60a but I haven't see that yet.
Reactions: sjpt
