If money was no object...
Q128C, KT sine-wave controller (14A), 48v 11.6Ah battery.
5,786
If money was no object, this is a 7150 € trike:
36 V Q100H - 19 speed pinion on the front and single speed SA freewheel in the back with 48 V battery big enough for 200+ km rides.
Or a Bafang Max drive in the front on a custom welded boom with a Rohloff in the rear wheel...
Or both versions, one for the weekend :)
spanos
259
67
So I'd have a Cove Hummer hardtail frame with bbs02
With very expensive front air suspension forks (topend rockshox for example). A nice sus post like the suntour or thudbuster
A b17 Brooks saddle
On one Mary bars
Hydro disc brakes . Shimano or avid upper end
Rohlhoff hub gears
Lekkie bling ring
Best /smallest battery for most Ah that Jimmy at insat can design when I throw money at him!
Those speeds and range from that battery is most impressive !
You don't get both at the same time!
It cruises on the flat at about 20 mph with 250w from the battery when you pedal medium. That would give 40 miles from a 500wh battery, but mine's actually 400wH (measured), so would do 32 miles. If it's hilly, that goes down to about 25 miles. Level 1 is 60w, so it'll go for 6 hours and 40 minutes. That's without free-wheeling, so you can say about 7.5 hours journey time at an average of 14 mph, which is 105 miles. To get 129 miles, I turned the power off sometimes when it was easy to pedal.
The power is fixed levels, so it's easy to calculate or estimate the range on any level. The display shows the watts and you can see that they don't change much until you select a different level.
Reactions: topographer
spanos
259
67
Ahh, makes more sense
#alwaysreadthesmallprint ;)
Quator94
30
Germany
www.ebiketester24.de
Wow, worth more than my car :eek:
5,786
Does your car have titanium leaf springs and a 19 speed gearbox? :cool: I bet it would cost a lot more if it did.
5,786
On the same note a guy in Brittany designed and built a 10 kg wood velomobile body with so-so aerodynamics for his trike and measured a 30% increase in speed. If you continue to ride at the same speed as without that would also translate to about 30% more range.
