i try buy which electric Trike Conversion Kit and battery for KMX Typhoon
Gh0stxSinghx
105
12
Luton, Bedfordshire
Hi all,
Im get KMX Typhoon soon, i buy e-bike kit no now, will later buy.
i want all electric Trike Conversion Kit 250watt and battery 36V. i ride on road uk.
please let me which e-bike kit link online, (Hub Motor, rear Wheel Type size, Speed Throttle, Controllers, e.g) Can match on KMX Typhoon
Jatinder Singh
30,648
For that 20" wheel in a recumbent you need a quite powerful legal rear wheel motor Jatinder. The eZee kit had often been used for that purpose and it has a variety of batteries and mounting options:
Cyclezee
30,648
I don't know of a low price high powered one for a 20" rear wheel Jatinder, but perhaps others will have a suggestion.
Hi all,
Jatinder Singh
We need a bit more informationfrom you to be able to advise correctly.
How fast do you want to go?
How hard can you pedal?
Do you have lots of hills on your rides?
How heavy are you?
How far do you want to go?
How much can you pay?
Are you good at DIY and do you know about electric stuff and can you solder?
Gh0stxSinghx
105
12
Luton, Bedfordshire
How heavy are you?
I know about ride on road uk 15.5mph,
I want all 36V 250w motor kit for up to 26mph and with battery, pedal + Throttle. good low pirce both motor kit, battery.
i was ride bike folding with e-bike and recumbent e-trike - electric Conversion Kit from conhismotor.com low price. last 2 years old KMX Tornado but problem wheel size on KMX Tornado from conhismotor.com and i try get cyclone e-bikes put KMX Tornado will never porblem. think sometime not good hard up hills and rain wet will braken for cyclone e-bikes.
My recumbent e-trike
[video=youtube;vSRS8of5zSo]http://www.youtube.com/watch?v=vSRS8of5zSo&feature=plcp[/video]
now i get KMX Typhoon need rear 20" Wheel Type size match any another see online.
Most of the 36v hub-motor kits will be much too slow in a 20" wheel - maybe 15mph max.
A 312rpm Bafang BPM will give about 20mph in a 20" wheel at 36v,so with a 48v battery, it'll just about reach 26mph - about £460 -£500 for both.
Bafang BPM 36V350W brushless hub motor kit for electric bicycle-GreenBikeKit online store for electric bicycle components-GreenBikeKit.com
48V12AH Headway 38140 battery, lifepo4/phosphate 48V12AH for electric vehicle online store for electric bicycle components-GreenBikeKit.com
Alloy charger for lifepo4, lead acid battery and lithium battery, 120W charger online store for electric bicycle components-GreenBikeKit.com
If you need cheaper, the 328rpm 36v Cute motor will do about 26mph at 44v. I think 48v would be too much for this motor, so you need lipos for the battery. You won't get as much torque as the BPM motor
GBK-100R 36V250W rear driving electric bike kit for DIY electric bike-GreenBikeKit online store for electric bicycle components-GreenBikeKit.com
4 of these and a charger plus some connectors.
ZIPPY Flightmax 5000mAh 6S1P 25C (DE Warehouse)
Gh0stxSinghx
105
12
Luton, Bedfordshire
Thanks d8veh. but not allow 350W on road uk, this can 250W. usa 350W on road lol. use off road the 350W to 1200W how i can go on road lol.
This all link is great size on KMX Typhoon?
motor much too slow in a 20" wheel 15mph full speed from 36V?
if 36V 24" rear wheel How fast full mph go? another 44V,46V?
24" rear wheel can put the KMX Typhoon?
if yes i will buy 24" wheel e-trike.
I forget tell about i want battery/batteries with Aluminium, bottle shape battery or rack battery + keys. Controller + LCD Display.
pedal speed + Throttle or Thumb.
Gh0stxSinghx
105
12
Luton, Bedfordshire
Hi d8veh, 36V250W~350W GBK-100R electric bike kit, rear driving e-bike conversion kit,
see link:
let me know size is great from KMX Typhoon?
KMX Typoon show pics and 13.5cm wide
View attachment 4228View attachment 4229
This can get work with battery-36V10AH, 36V 8.8AH?
link:
lifepo4, rack carrier mounted battery for e-bike online store for electric bicycle components-GreenBikeKit.com
36V10AH li-ion, Frog battery, for electric bicycle online store for electric bicycle components-GreenBikeKit.com
36V8.8AH bottle battery/ dolphin battery for electric bicycle, mounted on e-bike frame online store for electric bicycle components-GreenBikeKit.com
The motor is for 13.5cm wide bike.
This motor is less powerful than a Bafang 250w motor, so should be legal in UK with the 15amp controller in the kit.
You should select the 328 rpm option, which will give approximately 20mph in a 20" wheel. You want 26mph, which is not legal. If you really want 26mph, then you must use 12s lipos for 44v (48v average). I don't think that this motor is strong enough for a 48v LiFePO4 battery unless you reduce the current to about 12 amps. The 36v controller in the kit can run OK with 12S lipos, but not a 48v battery, so, if you want a 48v battery for higher speed, then you need to find a 12 amp 48v controller, which will be expensive. You could get the Greenbikekit 9FET controller and cut one of the shunts, which would give 11amps instead of the normal 22amps. A programmable controller from Ed Lyen or Emissionsfree.com would be better.
Gh0stxSinghx
105
12
Luton, Bedfordshire
No problem i buy for 20mph (328 rpm) - 36V250W~350W GBK-100R electric bike kit, rear driving e-bike conversion kit, let me which can work with 36V8.8Ah bottle battery/bottle shape battery for electric bicycle with charger can full speed 20mph?
21mph is the speed without load. 18mph would be about as fast as it'll go without pedalling on the flat. These motors are not high torque, so will slow down on the hills. You can get 20% more torque by soldering half of the shunt in the controller, but I think that the bottle battery can't give that much power.
Gh0stxSinghx
105
12
Luton, Bedfordshire
E-bike kits 36V250W rear driving including li-ion rack battery-GreenBikeKit online store for electric bicycle components-GreenBikeKit.com
21 mph is speed without load. The motor is small, so doesn't have a lot of torque. The rack battery in the kit would be able to give more mower than the bottle battery. In your first post, you wanted cheap, light-weight and legal, which is this kit
f you want 20mph without slowing down, you need this motor, with 312 rpm:
and this battery:
36V12AH 38140 lithium battery, headway battery for electric motorcycle online store for electric bicycle components-GreenBikeKit.com
You have to buy a charger too. The weight of this kit is double the other one and it's not legal, but that's what you need to sustain 20mph.
Gh0stxSinghx
105
12
Luton, Bedfordshire
36V250W GBK-100R electric bike kit, rear driving including rack battery36V10AH. - the on Legal road uk?
i see read sometime what's mean - tricycle – 0,25kW?
i get all e-trike kit full (Throttle + pedals speed)
This can allow throttle, without pedals speed on Legal road? and on up hill with pedals speed?
Until now, I've never heard of anybody being prosecuted for an illegal bike. It's almost impossible to prove that a kit is illegal if it's restricted to 15mph. Any kit that takes you to 20mph is illegal. Many of the ready-made supposed legal bikes that you can buy will go up to 20mph. Just don't run anybody over and you should be OK. Also, that motor's so small that nobody will notice that your trike is electric.
30,648
0.25 kW is just another way of saying 250 Watts. That's the old UK law that you've read, 200 Watts for bicycles, 250 Watts for tricycles. The EU law that we are subject to now is 250 Watts for both bicycles and tricycles.
