So, anyway, on my route home from work there's a short winding cycle path trough a wooded area. The path is shared half and half with pedestrians, going uphill the pedestrians are to the right. The first right turn is sharp and has bad sight-lines, so naturally I keep to the right to avoid the inevitable footpad who likes to dice with danger.
Today, coming up the path on the right, as usual, I was about 2 meters beyond the corner and I see a cyclist coming towards me. So I stay on the right giving him plenty of room to pass on my left. But instead I find my way blocked by this aggressive high minded idiot who proceeds to lecture me about how I should be on the right, he was pointing his arms and everything. I couldn't be bothered arguing, it's been a long day. So I let him rant for a bit and called him a k***head upon departure.
Things I wish I'd said:
1. The is a cycle path not a road.
2. Common sense also works.
3. You are causing an obstruction, I can have you arrested for that (not sure if that is true).
4. You are riding a bicycle, not a driving a car.
5. You didn't see that pedestrian did you?
On a cycle path I have always applied the same 'rules' as when walking on a footpath. Its not about keeping left or right, but using common sense when passing.
Karl
Karl
