I may never bother to pedal again ;-)
matthewslack
2,385
1,600
25kg in a backpack would be the end of me! Most of my stuff goes in panniers or a trailer, only the most delicate stuff on my back.
Reactions: Brik and gw8izr
spanos
267
79
How nice to see a many years later update!
As for your next bike. If you want move away from the an mtb then a hybrid frame will generally have more relaxed geometry than a gravel designed for drop bars.
I always like the look of the Genesis Smithfield with twin toptube as good candidate (but I do love a IGH)
You could have a down tube battery and have some weight on the rack, some in a backpack for better over all balence
Also a surtout ncx suspension seatpost is a game changer, come is 27.2 for hybrids as well
pedalfettal
73
37
You could change the rear brake to a disc-affair: You'd need:
A replacement disk wheel
Frame disk adaptor
Cable-operated disc brake and rotor
You could add the suspension seat post (already suggested)
You could also get a new disk-compatible air-shock front fork.
This'd keep your original bicycle frame, drive-train, etc, etc.
Or purchase a second-hand replacement and rob your existing bike for the motor and parts (mudguards, rack, handle-bar widgets, etc)
Reactions: gw8izr
gw8izr
239
252
If its just a comfort issue and better braking thats throwing a damper on your ride? May i suggest a suspension seatpost (#1 still on my wish list..)
I'm of an age where prostate comfort and potential damage is a consideration :) having said that my 'saddle with a hole' does a pretty good job.
Its not really a comfort issue but stability is certainly a concern.
And a front disk brake might be worth the investment even if it requires new forks and a wheel.. (also on my wishlist ) .
I could replace the front wheel and upgrade to disk as the fork has the lugs already.
Then again when you want a 'new' bike' and you deserve one. ;) sometimes you just gotta get one ..
That's the key issue.. I've lived with this bike for about twenty five years and whilst it's been better than OK I 'think' its time for a new bike.
Reactions: Bikes4two
gw8izr
239
252
I'll take a look at those, living here on Anglesey Island its a bit of a hassle getting to see stuff in the flesh but there we go. I'm nipping across the Chester on Friday to look at a friends bike with a Mid drive and Rohloff Hub which he absolutely raves about. At least I can ascertain the power difference as his motor is supposed to have 65n/m torque compared to my TZD which supposedly has 90n/m. This will be the first chance to ride a bike that I haven't ̶l̶o̶v̶i̶n̶g̶l̶y̶ ̶a̶s̶s̶e̶m̶b̶l̶e̶d̶ ̶f̶r̶o̶m̶ ̶a̶ ̶s̶e̶l̶e̶c̶t̶i̶o̶n̶ ̶o̶f̶ ̶c̶r̶a̶f̶t̶e̶d̶ ̶p̶a̶r̶t̶s̶ built myself...
I did a 15K walk on the coastal path today and was thinking about this comment a lot. It would be reasonably easy to fabricate a tray to take the existing battery and mount it where you (and others) have suggested, mainly as a trial but with effort I could make it look nice enough to use 'til the battery goes TU which is only a matter of time of course.
If it does make a significant difference to the handling then its an (almost) zero cost improvement.
The camera gear needs to stay on my back really, I wouldn't like to subject what is fairly precision gear to the vibration - and - when I get where I'm going I always have to abandon the bike and walk/scramble the last bit of the journey.
Ellen has one of those spring loaded seat posts on her hybrid and she rates it.. I think its awful so had dismissed them .. however having looked at this Suntour post it looks like a much more impressive affair and I'll certainly take a closer look Thank you.
gw8izr
239
252
25 Kg is the absolute limit of what I can cycle with on my back and then I really only use the bike to shorten a walk in on for example forestry tracks - where I can ditch the bike in the trees and walk the rest of the hill . Yes the weight is a killer. I have a much lighter camera setup for normal use and that's the more common load. In that case just 5 or so Kg, plus whatever food and drink I carry on top of that .
I've thought about a trailer but never pursued it beyond that... just thinking about a trailer now and my brakes :)
Peter.Bridge
1,557
717
There's loads of Boardman Hyb 8.6 s around of facebook for <£200. I'm converting one at the minute and it has hydraulic brakes, nice big frame triangle, square taper BSA bottom bracket , fixing points for a rear rack and mudguards , 11.2kg - ideal donor bike
Reactions: gw8izr
gw8izr
239
252
You could (snip)...
Thank you, Yes I agree all practical suggestions, I did sort of add up the cost of that lot and it left me thinking that :
Yes.. I think if I'm going to build rather than buy this is by far the best option.. I get to keep my motor that I know does what I need, I effectively get a 'new' bike and if the motor ever fails the current TZD motor is almost certainly a suitable replacement keeping everything else as it is now.
What I have learned over the years is that for my use I don't need anything like 60 miles range. So next time, a smaller capacity 48v downtube battery would certainly work out.
One issue I have is I'm totally out of touch with what is a decent MTB / Hybrid frame (whatever) these days and looking at the likes of FB marketplace reveals a bewildering array of bikes to look at :)
gw8izr
239
252
Charliefox
326
90
80
Culloden Moor Inverness
So rather than continue to clutter up somebody else’s post on rack battery matters I thought I’d better continue here.
The temporary arrangement that I’d used to attach the battery rack to the frame meant that it ended up to the rear of the axle and probably 3 inches above the tire, that meant the weight was very high and the bike felt quite unstable. Today I made some small aluminium brackets that allowed the rack to fit very close to the seat tube and only An inch and a half above the tire, even pushing the bike around the workshop it feels far better.
So I went outside, here on Anglesey it’s currently blowing a southwesterly at 70 mph and horizontal rain ..... I noticed the wheelie bin was now at the bottom of my field so I went back inside and put the kettle on!
Paul
Count yourself lucky! I get by on a rear hub motor and a carrier battery so yes, the rear weight is noticible. You soon get used to it though and the bonus is not much chance of going over the bars on a steep descent!! Plus loads of traction from the back tyre.
Reactions: gw8izr
Peter.Bridge
1,557
717
That looks in really nice condition - it will make a nice machine.
Are you going to hub drive or mid drive it?
It's for my friends wife, I'm going to keep it relatively light, so hub motor - a 280 rpm TBK100AD CST (2.1kg) and either a 36V bottle battery or a downtube battery. I know its a bit heavier but I think a downtube battery would give a bit more range - I seem to do much higher mileages on my rides than I would have predicted before I got an ebike.
Reactions: gw8izr
gw8izr
239
252
Yes for sure, I've lived with it for five years and it's been OK. I suppose I'm at the point where it needs to be better. I broke a couple of fingers last year and where in my youth it would have taken a few weeks to fully recover these took a year and still hurt like... Old age :) I think I need to make my bike harder to fall off
3,685
3,685
Not exactly a photo finish !
It was, according to what they broadcast! The girl was riding a Volt. Volt had a big presence during the filming. I think they asked (or paid) the producer to show their bike in a much better light. It was very disappointing that they hardly mentioned the Oxydrive kit during the show. Instead, Jason was bleating about the Boardman the whole time. I'm pretty sure that some shenanegans had been going on behind the scenes between the Gadget Show, Volt and Halfords, even though I bought the bike myself at my own expense specially for the show.
Brik
92
38
West Midlands
To the Original Poster, how many miles has your conversion covered and why no panniers?
My Bafang conversion has done three winters and 6000 miles. No issues with the motor but I have noticed the battery is slightly less efficient.
Cheers,
Rich
Reactions: gw8izr
gw8izr
239
252
Hi, I've no idea as the odometer mysteriously reset to zero after a few years, it's currently back to a few thousand. I don't do many miles really but I'd guess 6K or so is a fair estimate. During 2020/1 here in Wales we had lots of restriction on use and last year I had set some targets for long distance walking so the bike hardly moved. (I walk about 4000Km a year)
I think my bike is slowly changing from just a tool to get me to my photography locations to something I will hopefully use for general exercise as well.
I've recently resurrected the bike as my walking isn't doing enough cardio for me, I was out yesterday and did 15 miles on the Coastal path but whilst that's great endurance it didn't really do any cardio at all. Sadly I can't run anymore as my old knees are stuffed but I can still spin along.
I've just come back from 25 miles of easy riding round the lanes but by pushing faster than the speed cut off I was able to hold my heart rate at Zone 3/4 for the entire ride. If I hadn't had the motor assist my knees would crumble at the first hill ..
I hate them :) I never got on with them when I did a bit of touring but for sure if I needed to carry a tent etc it would probably be the best way. It must be me but when I chuck my leg over the bike they just seem to get in the way.
I did have an old respirator case mounted as a pannier for years to carry my spare tube / bits of tools and my flask & butties but I can't attach my camera stuff to the bike..
If I drop the bike and walk to take a shot I'd have to unpack the pannier and put the gear into my backpack anyway so it sort of doesn't work for me.
That's good, my motor has also been faultless and I'd have another without hesitation if the rest of the bike was what I think I need now.
Funny you should mention that about the battery. I did say earlier on in this thread that the battery was 'slightly' worse after 5 years of use ( bear in mind that's a couple of years of almost no use which is really bad news)
I have just done a couple of complete 'full to flat' cycles and today I reckon the battery is actually a lot worse than I initially thought. Its on charge again now and I'll watch it more carefully for the next couple of charges .
Regards Paul
Reactions: Bikes4two and Brik
nigelbb
511
422
I haven't got any photos but one of my eBikes is a Boardman Hybrid 8.6 that I got through the Cycle to Work Scheme then subsequently converted by Woosh with a front hub motor. It's a great bike with excellent brakes.
Peter.Bridge
1,557
717
Raboa
873
314
53
I would buy a connex chain if using a mid drive, you don't need any tools to take off and put back on. You still need a chain tool to get the correct length, makes cleaning the chain slightly easier, I oil my chain at the same time as well.
Reactions: gw8izr
