Another correcting factor is that steel rims when they were de rigeur were useless for braking in the wet, hence the near universal change to alloy. But discs of course are still stuck with steel on bicycles, not so good as alloy in the wet. Carbon fibre is used on race cars of course.Just out of interest what about in the wet? The rims on a bike surely pick up more water than a disk would and so would take longer to clear and so get full brake efficiency ?.
Take your point about Alloy v Steel but as for Carbon Fibre Formula 1 and MotoGP definitely can use them but most other racing classes state ferrous brakes only to keep costs down etc.Another correcting factor is that steel rims when they were de rigeur were useless for braking in the wet, hence the near universal change to alloy. But discs of course are still stuck with steel on bicycles, not so good as alloy in the wet. Carbon fibre is used on race cars of course.
Hmm after a bit more research found this: -Take your point about Alloy v Steel but as for Carbon Fibre Formula 1 and MotoGP definitely can use them but most other racing classes state ferrous brakes only to keep costs down etc.
Hi JonHi Bob...
A policy of component standardisation is a great move for Juicy, imo. Did you have any luck sourcing a cartridge-type bottom bracket for your latest designs?
Edit: it'd be worth updating your website with the Tektro info, otherwise people knowing the old spec may assume that this hasn't changed. Also, I'd say 20Kg is a touch too light for the weight; although it may have changed, it'll certainly increase with the higher-range batteries. My Sport 2010 (10Ah) was around 23Kg on the bathroom scales![]()
Great stuff, a good change I think.Yes, we now use a cartridge on the bottom bracket, preferred by LBSs but more expensive.
Ah, that sounds about right, good stuff; mine came in circa 23Kg on the scales, with the 10AHThe weight of the bike is 19.4 Kgs without the battery and the 10AH battery that we use is a tad over 3Kgs.
It is indeed good that we are free to choose, Neptune, but as a motorcyclist of some 37 years' experience who's owned everything from pre-unit Triumphs to the latest litre sportsbikes I can tell you what brakes I'd prefer to be using - regardless of the machine or it's top speed capability.I think my post about the Norton drum brake was misunderstood. Obviously the multi piston disc brakes on a modern sports bike are far superior, but then the performance of the bike is much higher. On the Norton, you did not have the problem of slowing from 180 MPH, and it is unlikely that you would have that problem on an ebike, unless youre bike performs better than mine.
What I was saying was that the Norton had excellent brakes without the use of discs or hydraulics, so we should be able to stop an ebike without discs or hydraulics. Hydraulic discs and cable Vee brakes both have their advantages and disadvantages. It is good that we are free to choose either.
It was designed for exactly this application - upgrading an old canti system to V-brakes, but keeping the original levers.Now lets talk about the "leverage reducer". I had noticed that the actual brake levers on a Vee brake set up were short compared to the ones used for the old side pull brakes. I had assumed that this was because Vee brakes are very powerful, and the short levers were fitted to prevent wheel lock. But your post implies that the leverage reducer exists as a separate physical component. If this is true, where is it fitted, how does it work, and what does it look like?
Many years ago when I changed a front brake from cantilever to v-brake I wanted to keep the original integrated levers so fitted a ‘Travel Agent’. This device effectively turns a short pull lever into a long pull one. It works well and is still on the bike.Now lets talk about the "leverage reducer". I had noticed that the actual brake levers on a Vee brake set up were short compared to the ones used for the old side pull brakes. I had assumed that this was because Vee brakes are very powerful, and the short levers were fitted to prevent wheel lock. But your post implies that the leverage reducer exists as a separate physical component. If this is true, where is it fitted, how does it work, and what does it look like? .
