Hybrid Mudguards for KTM Macina Cross 9 ?
Here they are. If you take your time, you can do it better than this, but it should get across the idea:
This is the shape of the new type at the rear. The front matches it:
Here they are on my Rocky Mountain so that you can see what they look like:
Polava??? As you can see, it took about 5 minutes to fit both of them. It's more hassle to clean your bike!
Reactions: musicbooks
mfj197
553
160
Guildford
The only problems I can see with the SKS Beavertail XL is that you might well have to do a bit of cutting to get them to fit. You mention the width of the rear crossmember is 46mm, and also I know the tyres fitted to your bike are 42mm maximum width. The Beavertail XL is marketed as "Especially for all Mountainbikes with extra fat tires" (which yours certainly aren't) and mentions tyres up to 54mm wide - wider than your 46mm mount. I think for a similar style mudguard I'd look at the SKS Velo 47 Trekking, or you might even be able to get away with the SKS Velo 42 Urban.
Michael
