Hub motor swap from Bafang to MXUS
niilo
Apr 12, 2018
Finland
Hi all. Don't like to catch your thread but asking just about swap between Bafang-8fun-SWX02 to MXUS-XF15F swap (front).
Reason for this is just to have different width of tires available on different conditions ( 29" and 26-fat) .
Now I do have Bafang installed with 29" and running OK.
Just received MXUS, plugged in 9-pind round connector (still w/o wheel) and tested it. Wondered as it took only 30W and running only just 5km/h.
As (wheel not touching ground) with Bafang, just hits 30km/h what's set as limit for controller.
So, is it normal or do they have different parameters ?
Thought, they do have same electrical construction.
Thanks in Advance
Attached below just 8fun specs.View attachment 41240
niilo
Apr 12, 2018
Finland
Thanks in Advance
This was my bad: Bafang given 6 pulses/round as MXUS 1/round.
After this ( LCD3,P2 6-->1) shows correct and rotates also as expected. Haven't change to test as spokes not installed yet.
