Hub Motor Kit Outlet
Save yourself some dosh. This bike has strong steel forks - ideal for a BPM motor. It's nice and strong for people that ate a pie or two too many.
Fit the BPM kit, upgrade the brakes to branded hydraulics, and you'll have change out of £800. Forget about your hub gears. They're no big deal. You won't need any gears anyway with a Big Bear kit.
http://www.ebay.co.uk/itm/Muddyfox-Livewire-26-Dual-Suspension-Bike-Disc-Brakes-12-Month-UK-Warranty-/122247692197?hash=item1c7687bfa5:g:SjUAAOSwi0RXxBaE
Reactions: Andy88
Andy88
747
135
69
Ayrshire
Thanks Dave, that's the push I needed.
Andy88
747
135
69
Ayrshire
Did you mean keep derailleurs and also stick to BPM over Crank Drive?
Put BPM on front or back wheel?
Battery in pannier or downpipe?
8,841
B/B = Bottom Bracket.
BPM is Bafang front wheel hub, equivalent rear wheel hub is a CST.
Hub gears (IGH) can only be used with front hub or Crank drive.
Eccentric B/B an oversized B/B shell casing that holds a standard B/B in a special eccentric insert to allow chain tension, negates the need to use special rear drop outs and derailleur type chain tensioner.
Reactions: Andy88
Andy88
747
135
69
Ayrshire
That's something else I've learnt, thanks
Keep the derailleur gears and fit a Big Bear kit, not a central motor. Any time in the future, you can swap the Big Bear kit to any other bike, in which case you'd only lose about £70 when you sell the bike as second hand. You will then learn from your experience and be in a good position to buy a different bike if you want.
One thing I've found from all my experience of converting high-end and low-end bikes is that they all work pretty well. You only need something special when you're an experienced discerning cyclist.
Reactions: Andy88
Andy88
747
135
69
Ayrshire
I get you dave.
You favour the big bear kit at £599 over Oxydrive and Cyclotricity? The latter is direct drive?
Andy88
747
135
69
Ayrshire
Anything wrong with buying second hand £175 to £250? Ive seen cubes, ridgebacks, etc less than a year old at those prices where their original price more than double!
That's another thing I notice, depreciation seems high on a lot of bikes both electric and pedal.
Andy88
747
135
69
Ayrshire
Tabs
279
132
65
Scotland
Heavy people need a strong motor with high current. Only the Big Bear kit meets those requirements and sort of legal. You need strong forks for the Big Bear motor. Best are ones with 5mm plate dropouts. Thin spindly steel road bike type forks are probably not strong enough. I wouldn't recommend using any light alloy forks. You can change the forks on any bike. Used steel ones are about £30.
The Oxydrive rear kit is good for medium to heavy weight people, especially if you want to go fast, but at only 15 amps, it lacks the BB's grunt. The front motor Oxydrive kit is smaller and less powerful, so better for medium to light people.
Tabs
279
132
65
Scotland
Am 21+stone and am well impressed with the ability of the conversion kit so far (am expecting to replace bearings or the motor at some point) it lets me keep up with guys who are 20/30 year younger than me and if truth be told ad have got one 40 year ago if they were available.
Andy88
747
135
69
Ayrshire
Perfect, nothing wrong with the gumtree bike looks good on the rack.
Andy88
747
135
69
Ayrshire
Thanks again, so it boils down to bite the bullet on derailleurs forget the hub motors, which add more weight anyway. Then either take the big bear off the shelf for £1,099 or get a sturdy bike like the pic you sent or strong second hand around £200 and convert £600 + fitting and extras £100 + Bike £175 to £225 making it £875 to £925.
Tabs
279
132
65
Scotland
In your case I'd just buy the big bear for £1100 and enjoy the experience.
Reactions: Andy88
LeighPing
2,547
1,945
The Red Ditch
The only reason that I would go for a lighter ebike, fitted with a kit, would be to throw it around cross country. They're a nightmare to pedal unassisted. :)
Reactions: Tabs
