Hi all,
I usually push off using throttle due to limited mobility in my legs and manage 7-9mph at times with use of throttle intermittently.
I have a KT sensorless controller and LCD3 fitted to a 200w geared hub motored ebike. Shimano 6 speed. 16" wheels with 235rpm. 24v 17.5ah battery.
At the moment I'm unable to pedal much. What is the best display setting for pedal assist, and do you have any riding advice, so as to achieve cycling/motor efficiency?
