April 14, 20188 yr As some of you might know, I recently purchased the Radrhino e-bike. It's a gorgeous and very functional machine. I had 4 e-bikes in my life and this is by far the best. It's like a tank with a sport-y mode. Anyhoo, is there a way I can camouflage the printing on the motor to read 250w instead of 750w? The bike is limited to 15.5mph and I don't think it's worth taking a risk for power I'm not actually using. I don't even like speed or using a setting higher than pedal assist 3 (the bike's got 5 levels of pedal assist).
April 14, 20188 yr A smear of dirty grease? Or leave it as it is and say its part of the model identification number
April 14, 20188 yr As some of you might know, I recently purchased the Radrhino e-bike. It's a gorgeous and very functional machine. I had 4 e-bikes in my life and this is by far the best. It's like a tank with a sport-y mode. Anyhoo, is there a way I can camouflage the printing on the motor to read 250w instead of 750w? The bike is limited to 15.5mph and I don't think it's worth taking a risk for power I'm not actually using. I don't even like speed or using a setting higher than pedal assist 3 (the bike's got 5 levels of pedal assist). [ATTACH=full]24192[/ATTACH] just ask your supplier for a sticker that says 250W nominal - EN15194 supplied by XYZ - Made in China
April 14, 20188 yr D8's got a way to make your own aluminium sticker, I'm sure one will be along presently.
April 14, 20188 yr Author just ask your supplier for a sticker that says 250W nominal - EN15194 supplied by XYZ - Made in China Can I just print out (if I figure out how) an aluminium sticker with the same info printed on the motor? I don't think my supplier would provide me with a sticker, they're kind of uptight.
April 14, 20188 yr Author D8's got a way to make your own aluminium sticker, I'm sure one will be along presently. D8, are you there?
April 14, 20188 yr Can I just print out (if I figure out how) an aluminium sticker with the same info printed on the motor? I don't think my supplier would provide me with a sticker, they're kind of uptight. No, you can't self certify. You have no idea if the motor was submitted to EN15194 certification or not. Your supplier should have the information, if not, they can call the manufacturer.
April 14, 20188 yr Author No, you can't self certify. You have no idea if the motor was submitted to EN15194 certification or not. Your supplier should have the information, if not, they can call the manufacturer. Sorry, I don't follow. Are you referring to the serial number or the wattage or both?
April 14, 20188 yr Sorry, I don't follow. Are you referring to the serial number or the wattage or both? no, neither serial number or wattage matters. if you print your label without a certificate of conformity, your motor is not road legal. If you have the certificate of conformity and print the label yourself, you may pass off the trademark. Either possibility is not good. The supplier should give you that label if the motor was and is certified for EN15194 or authorise you by email to print that label yourself.
April 14, 20188 yr To make the label you need a laser printer or photocopier. 2" wide aluminium tape (DIY shop) and wide selotape. Design the label on your PC Print it on normal paper Fix the aluminium tape directly over the print with a Pritt stick or by tacking it in place with selotape just holding its edges. Leave the backing on for now. Put it back in the printer and print again. Same if you're using a photocopier. Now the aluminium should be printed. Remove it from the paper Cover the whole thing with wide selotape being careful not to get creases. Cut to size Peel off backing and stick on motor.
April 15, 20188 yr Author To make the label you need a laser printer or photocopier. 2" wide aluminium tape (DIY shop) and wide selotape. Cut to size Peel off backing and stick on motor. Thanks!! I'll give it a shot. Do I need to spray the motor surface with clear varnish or something after the label has been applied?
April 15, 20188 yr I have an EN15194:2009 Certificate of Conformity that came with my BBSHD kit.. along with a nice aluminum plate affixed to the underside of da mota..
April 15, 20188 yr Author I have an EN15194:2009 Certificate of Conformity that came with my BBSHD kit.. along with a nice aluminum plate affixed to the underside of da mota.. I've got a certificate of conformity too - came with the bike, but as you see the wattage is printed right on the motor. No plates.
April 15, 20188 yr Excuse my ignorance but why did the company sell you an illegal bike for uk use Or am I missing something (Genuine question)
April 15, 20188 yr Excuse my ignorance but why did the company sell you an illegal bike for uk use Or am I missing something It isn't illegal in the EU or UK, this is what the company say on their site: Falls into the L1e-A electric bike category That is what was once known as the Low Powered Moped class, bicycle based, restricted to 25 kph (15.5mph), up to 1000 watts rating. Usage is subject to the country it's used in. In the UK it has to be registered, number plated and insured, but no driving licence necessary. It's actually fitted with a rear number plate mounting and complies with all the L1e-A requirements. Some avoid registration etc and use them illegally, personal choice on the risks. .
April 15, 20188 yr Thanks!! I'll give it a shot. Do I need to spray the motor surface with clear varnish or something after the label has been applied? No. The clear sellotape makes it waterproof.
April 15, 20188 yr It isn't illegal in the EU or UK, this is what the company say on their site: Falls into the L1e-A electric bike category That is what was once known as the Low Powered Moped class, bicycle based, restricted to 25 kph (15.5mph), up to 1000 watts rating. Usage is subject to the country it's used in. In the UK it has to be registered, number plated and insured, but no driving licence necessary. It's actually fitted with a rear number plate mounting and complies with all the L1e-A requirements. Some avoid registration etc and use them illegally, personal choice on the risks. . Nice one thanks for the info
April 15, 20188 yr Nice one thanks for the info. You have to be careful nowadays. They're checking on bikes in my manor! https://www.youtube.com/watch?v=NJSgGcjwIEU
April 15, 20188 yr https://www.ebay.co.uk/itm/e-bike-hub-motor/182916973134?hash=item2a96b3824e:g:mKkAAOSwL5BZxDg-
April 15, 20188 yr No, you can't self certify. You have no idea if the motor was submitted to EN15194 certification or not. Your supplier should have the information, if not, they can call the manufacturer. My Woosh bike doesn't have the wattage engraved on the Bafang motor only the voltage 36V. Just a sticky label on the frame which can easily be removed.
April 15, 20188 yr No. The clear sellotape makes it waterproof. Sellotape pah! It's so 1970's ...But Clear Gorilla tape is "The business" even good for frame protection. Buy a roll you won't be sorry.
April 15, 20188 yr No. The clear sellotape makes it waterproof. Im not trying to be awkward here but selotape is rubbish when it gets wet It goes all milky and loses its adhesive property's and makes a right mess You would be better off with a clear vinyl or similar.
April 15, 20188 yr Sellotape pah! It's so 1970's ...But Clear Gorilla tape is "The business" even good for frame protection. Buy a roll you won't be sorry. Is it good when it gets wet ? If so definitely worth a go
