Thanks - my husband has been looking into this and might use my old tyres to trim and put in his as a type of liner.
I got given this tip by another biker a long time ago, and it really works. Trim the old tread a bit longer, some 2-3 cms longer, as when the air expands in theinner tube, a longer length is needed.Thanks - my husband has been looking into this and might use my old tyres to trim and put in his as a type of liner.
yes it does add a bit of weight, you can notice it more when the bike has been stood for an hour or so and the slime all works its way to the bottom, if you spin the wheel you can tell it’s out of balance. Of course once you start moving it all distributes and you can’t feel it at all then.added that sealant to the inner tube as well (which I guess brings a tiny bit more weight too)
Thanks. I have only used it on tubelss car tyres, where the steel wheels were leaking slightly, as the car was from new, supplied with inner tubes, which on cars and trailers I hate! It worked well for the rest of the time that I drove that car!!yes it does add a bit of weight, you can notice it more when the bike has been stood for an hour or so and the slime all works its way to the bottom, if you spin the wheel you can tell it’s out of balance. Of course once you start moving it all distributes and you can’t feel it at all then.
