How to add a throttle to a Carrera Vengeance E Spec
rajeshtailor
170
I've just tested this new code and it is exhibiting the same behaviour.
1. No errors when I power on.
2. Throttle runs nicely.
3. Release the throttle, when mph reading drops to approx 10 then error 22 is displayed.
But I'm wondering if this error is coming from the pedalon code like you said earlier?
17,301
not sure. Try changing the formula first.
Error 22 may come from the fact that the controller knows the speed of the bike, your code doesn't, so you may have to add a procedure to gracefully exit the throttle.
Can you test the new formula for me?
Run this code:
Code:
Code:
// Experimenting
// PAS Cadence Input Pin - D2 (Digital)
// PAS Torque Input Pin - A3 (Analog)
// Throttle Input Pin - A0 (Analog)
// Controller Cadence Output Pin - D13 (Digital)
// Controller Torque Output Pin - A5 (Analog)
int pulseoff = 150; // milliseconds when synthesised cadence is low
int pulseon = 100;   // pulse low  - cadence reduced to 4Hz
int val = 0;
int torqueval = 0;
bool pulse = false;
bool throttle = false;
int pedalin = 2;
unsigned long startMillis;
unsigned long currentMillis;
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(A3, INPUT); //PASTorquePin
  pinMode(A5, OUTPUT); //ControllerTorquePin
  pinMode(pedalin, INPUT);
  digitalWrite(LED_BUILTIN, LOW);
  startMillis = millis();
  Serial.begin(9600);
void loop() {
    if (millis()>currentMillis) // run once every millisecond
        currentMillis = millis();
        analogWrite(A5, (analogRead(A0) > 290) ? analogRead(A0)*2 + 308 : 0);
        pulse = true;
        if (currentMillis > (startMillis + pulseon)) pulse = false;
        if (currentMillis > (startMillis + pulseon + pulseoff)) startMillis = millis();     // reset timer clock
        if (pulse) digitalWrite(LED_BUILTIN, HIGH);
        else digitalWrite(LED_BUILTIN, LOW);
8,781
All this techy figures and Arduino stuff is way over my head, but kudos for sticking and persevering to finding a solution that will make the code work.
Reactions: snafu and Woosh
17,301
Raj, I reduced the frequency of the cadence from 6Hz to 4Hz to see if error 22 gets shifted to lower speed accordingly.
rajeshtailor
170
Run this code:
Code:
Code:
// Experimenting
int pulseon = 100;   // milliseconds when synthesised cadence is high 6Hz
int val = 0;
int torqueval = 0;
bool pulse = false;
int pedalin = 2;
void setup() {
  Serial.begin(9600);
void loop() {
        analogWrite(A5, (analogRead(A0) > 290) ? analogRead(A0)*2 + 308 : 0));
        pulse = true;
Just tested this code. Results as follows:
1. Power on the bike, returned error 21.
FYI there were too many brackets in the analogWrite line so i removed the last bracket on that line to make it compile.
17,301
yes, there was one ) too many. I amended it and thank you for testing that code.
Can you test the last working version but with lower cadence?
I try to figure out why the errors 21 and 22.
rajeshtailor
170
Just tested the previous version of the code with lower cadence, results as follows:
1. Power on the bike, no errors.
2. Run throttle, no errors, release throttle approx 3secs later error 22 displayed.
Below is the code just for reference the error may have been caused by the pedalon code shall i remove the pedalon code?:
Code:
// Experimenting v4
// PAS Cadence Input Pin - A2 (Analog)
int val = 0;
bool pulse = false;
int throttleperc = 0;
int torqueperc = 0;
int torqueval = 76;
//int pedalin = 2;
void setup() {
  pinMode(A2, INPUT); //PASCadencePin
  Serial.begin(9600);
void loop() {
        val = analogRead(A0); // Read the value from the throttle pin A0
        //throttleperc = ((float)(val - 290) / (float)577) * 100;
        //torqueperc = 164 * ((float)(val - 290) / (float)577);
        //torqueval = 76 + torqueperc;
        torqueval = 0;
        if (val < 290)
                // I'm pedalling
                int pascadence = 0;
                int pastorque = 0;
                pascadence = analogRead(A2); // Read the value from the PASCadence Pin
                pastorque = analogRead(A3); // Read the value from the PASTorque Pin
                //Serial.print("Pas Cadence value is ");
                //Serial.print(pascadence);
                //Serial.print(" PAS Torque value is ");
                //Serial.print(pastorque);
                //Serial.println("");
                int cadence_threshold = 500;
                analogWrite(A5, analogRead(A3)); // you need to check synthesised torque with a multitester
                if (analogRead(A2) > cadence_threshold) digitalWrite(LED_BUILTIN, HIGH);
        else
            //I'm using the throttle
            //torqueval = 76+(val-290)*164/287; // your experimental formulae
            torqueval = (308 + val * (880-308)/(577-290));
            analogWrite(A5, torqueval);
            pulse = true;
17,301
yes, it can be removed by simply supressing the cadence:
change to:
could you let me know the test result?
rajeshtailor
170
change to:
Just tested this and
1. on powering on the bike I get error 21.
2. I press the throttle then power on the bike motor runs I then let go of throttle and get error 22.
i actually think the throttle code is fine I think we now need to nail the code that runs when we are pedalling.
i think we need to take the reading from the PAS torque pin which will be between 0-1023 however when we are writing out to the controller we need to divide that value by 4 for the correct PWM. (I could be completely wrong).
to test this we should just write a minimum value of 76 to the torque output pin without the PAS wired in.
I won’t get loads of time to test this weekend but I’ll be back on testing Monday.
17,301
yes, I think you are right on this.
Change to:
analogWrite(A5, analogRead(A3)/4);
also:
change to:
analogWrite(A5, torqueval /4);
rajeshtailor
170
Change to:
also:
change to:
I have made these changes and am ready to test, will update you once I have tested.
Evian1040
75
9
I'm following what has been posted here, so the code is the latest from raj with your modifications you requested to change and the diagram is the same as raj.
Now i can't debug mine since i don't have access to it (long story short my nano does not have a bootloader so it can be instant on power up on the bike, if it does have a bootloader then i get error 21 because its too slow to give the torque power, on power up)
17,301
did your throttle work before error 21 shows up?
also, could you run this test to help me figure out where the error comes from?
note: connect cadence input to A2.
The reason is we need to be sure we can debounce the signal if needed.
Code:
// Experimenting
void setup() {
  pinMode(A2, INPUT); // PAS cadence Pin
void loop() {   // does cadence input cause errors?
    if (analogRead(A2) < 500) digitalWrite(LED_BUILTIN, LOW);
    else  digitalWrite(LED_BUILTIN, HIGH);   // blink LED
If all is well, it should blink the LED when you turn the cranks without producing error 21 or 22.
Evian1040
75
9
Tried it, just on power up it went error 21.
EDIT: Tested to see if the arduino is ok and its responding ok. Also confirmed the wiring is ok by connecting the torque without the nano so it proves its the code. (wanted to make sure i'm ok on my side before sending us all on a wild goose chase)
17,301
did you connect cadence input to A2?
Evian1040
75
9
Yes, and also tried without.
EDIT: I just saw that i copied your old code before it was edited.
17,301
did the arduino LED blink when you turn the cranks?
Evian1040
75
9
No, if it turn on the pedals there is no blinking. Turning on the throttle is a solid light.
Also it still failed with error 21 on power on
