how to 360 them handlebars and not look diy
16,852
good find SW.
Fat Rat
1,903
726
UK
The transition from the bottom of the crown to the calliper will still be a bit of a mess operation wise
As you will lose the ability when on compression to arc the brake pipe
What will happen is it will be forced to slide up and down the steerer and through the cap if you get my drift and eventually wear the pipe away or cut into something else as pipes have a habit of doing especially when dirty .
Nearly a good idea but no prize from me
craiggor
498
171
I thought these things where for BMX bikes with just a front brake to enable the bars to turn 360 degrees. If so what's the point of one of these on an ebike with front and rear brakes, brake cut outs and display wires.
Sent from my K107 using Tapatalk
Reactions: Gringo
Fat Rat
1,903
726
UK
Non at all
I think there more aimed at urban jump bikes
6,487
Related Articles
