If they are Hall effect motors, the Hall sensor signal rate to the controller circuit automatically indicates speed Rooel, the same as the Wisper one and many others. The controller can then dictate a cut-off speed, not issuing phase current beyond a certain pulse speed.
The pedelec disc type that beeps mentions only applies to some hub-motor bikes, I think the minority now, since if the pedelec ring is on the BB spindle as it often is, it has the disadvantage of limiting power at high pedal rates in every gear, not just top.
Most like Wisper, and eZee where limited, use motor Hall sensor feedback to the controller.
