Hello and greetings from sunny Paris to everyone
It has been a long time I haven't written on the forum (although I've been reading with interest).
I'm in a need of little of your help with my Pro connect (Panasonic crank drive 2010 version)
From this spring the motor of my bike has developed a sound like something is rubbing against one another or against the walls inside of the unit. The rubbing sound ceases instantly when the power is cut off, but is especially heard under load and when reducing the cycling cadence. It has nothing to do with transmission, as I've changed all of it a couple of times since then.
Why I also think it is the motor problem, is because I read in some thread where Flecc explained that if grease is lacking on the nailon wheel then one of the indications is that if the bike is not used for some time, the problem might get worse before the grease is more evenly distributed when riding again. Moreover, with warmer whether, the problem should lessen (as it has a direct effect on grease distribution). Well, this is exactly what I'm experiencing as the rubbing almost disappeared during warm July and August days. But now, with chilling mornings, it has become back wit a vengeance and is appearently getting worse (and is especially strong if I haven't used the bike for a week or so). I've done around 10000-12000 km with my bike in all wheather (even in winter). I've used it in normal and high mode most of the time and more intensively than the average user as I have 41 teeth chain wheel, 11 teeth motor sprocket and 11-28 cassette installed on my bike which gives a max speed of 35-36 km/h.
I really don't want to break down the motor as I'm now out of the 2 year warranty. Therefore, I would like to know how complicated it is to open the motor and repair the problem? Although having owned my bike for more than 2 years I'm now doing all the repair work myself, I'm not really a hands-on person by profession So I don't know if I'm capable of greasing the nylon wheel (if this is really the issue) without breaking or messing something up
Therore I would like to ask your advice on the subject how to proceed.
Thanks and have a nice and sunny Sunday
Vaasa
Vaasa
