I found that ok, but the sensor wire is faulty.....( unless I need to do something other than add the throttle...?? )View attachment 12162
This is what your looking for hanging off the controller the. Throttle plugs in to this.
Must be the wire that is at fault as all you need to do is plug in the throttle. Nothing else is needed. Did it plug in ok? Is the throttle faulty?I found that ok, but the sensor wire is faulty.....( unless I need to do something other than add the throttle...?? )
Hi Scott, I am toying with fitting a thumb throttle to mine, does any type fit/work, Can you explain how I would use it - ie does it override the LED thingie in respect of low - med - high, is it completely smooth in operation or is the power delivery stepped. I am hoping to get my wife - who hasn't ridden in years - to use the Shopper and so want to make it easy for her. Oh and where did you get yours from ? ThanksView attachment 12162
Hi the throttle I have is the motorcycle type ( looks like one but isn't off a motorbike) rather than the thumb type. I had to extend the length of cable and re attach the plug but it just plug right in with no problems at all. As you turn the throttle you pull away as you would on a motorbike and this over rides the settings on your L.E.D and you get full speed at full throttle. If you start to peddle and roll the throttle off this then sets you back to what ever setting you had on your L.E.D. And you can just peddle away. I got mine from Amazon in the end and aslong as it is the plug in type you should be ok. Just check your electrics under your battery cover to make sure it's the same as mine in my pictures and you should be ready to plug and play.Hi Scott, I am toying with fitting a thumb throttle to mine, does any type fit/work, Can you explain how I would use it - ie does it override the LED thingie in respect of low - med - high, is it completely smooth in operation or is the power delivery stepped. I am hoping to get my wife - who hasn't ridden in years - to use the Shopper and so want to make it easy for her. Oh and where did you get yours from ? Thanks
Oh and where did you get yours from ? Thanks[/Q
http://www.pandaebikes.com/product-category/ebike-accessories/page/4/ All you need here. UK based and reliable service.
Scott I ordered a thumb because I wanted to fit on the left side because of the gearchange and twist type would not (in my mind ) work the right way about. Now I see you have the SE which has the 6 speed - so how did you fit it all - can you post a photo please.Hi the throttle I have is the motorcycle type ( looks like one but isn't off a motorbike) rather than the .................
I have a thumb throttle you can have for postage fees.Thanks for that Scott and Kuorider, unfortunately Panda want £12 to send it to Spain, will have to look elsewhere.
Oooops something I am doing all the time - forewarned and all that , thanks.Be careful not to pick the bike up using the handle on the back of the frog style battery............
Thankyou for that but had ordered one almost immediately .I have a thumb throttle you can have for postage fees.
