Hi Jason,
If the outer cover is stuck or jammed, you can set up a puller as shown in the photo. (Obviously remove the cover screws and crankshaft circlip first)
Once the main motor bearing is noisy, it is destroying itself. When it collapses the ball bearings come out the bearing and start running in between the cover and the main motor drive gear. The damage is fairly catastrophic. The problem comes when trying to fit the new bearing. It will not seat square, or at the right depth.
As for your broken lugs. I have tried different specialist aluminium adhesives on these, with little success. The torque loading on these lugs is particularly high and with two broken, you stand little chance of fixing them. Don't be tempted to tig weld them with the circuit board attached either.
The good news is that I do have casings and enough second hand parts to get you going again
Contact me at
peter.collard@performancelinebearings.com
