Help! HELP with QR ON EBIKE
6,581
there all the same tbh just clamp it as tight as you can or you need a frame with thru axles 12x148 boost is the new standard hub wise
Abzy
175
I tightened it as hard as I could but would the dt Swiss ratchet 5mm be better ?
6,581
yes but it wont be anything like a thru axle but it depends what you use the bike for my m8 has a 1000w bafang motor he goes to work on and has dropouts and not had a problem
tho if he raced me down a mtb trail it will fall to bits
Abzy
175
I use the bike for commuting that's all don't have a mtb trail where I live
6,581
well now you have the qr on the right way round it should be ok ;)
i go that fast to tesco :p
3,296
Even if you mange to tighten it further - you've filed the dropouts and every time the axle moves just a bit, steel will keep on wearing away more material from the aluminium dropouts so that over time they will become even looser. Steel putty is a composite which contains steel - not as strong as steel - so that will also wear away. Welding aluminium on will change the properties of the heated part of the aluminium frame.
6,581
Abzy
175
So what should I do to stop it from wearing away
3,296
I don't think you can. Buy a new secondhand frame. It really is the best option IMHO.
6,581
if you have a mid drive motor the rear drop outs are kaput you need a new frame
Reactions: guerney
6,581
i found a new one for 50 quid hub and free hub body micro spline 12spd shitmano just needs to be laced in to his rims and spokes.
and thats on a 5k canyon bike from 2019 its a fkn heap of shite lol
Abzy
175
Link ?
Abzy
175
Could someone find me a cheap frame and someone who's willing to take my old frame rough how much would I get out of this old frame? Since it's only been about 6-7 months
3,296
You'll have to keep searching ebay periodically, gumtree etc. for a frame compatible with your components
