I did the same initially, disassembled it and applied some lithium grease then put back together. It still to rotated smoothly after that. Was surprised in doing so to only find 6 magnets in it, aren’t these supposed to have 12?View attachment 24135 Thank you guys for responding,
Tried changing the c1 settings, no joy there,
I have removed the sensor, it looks like I might have tightened the pedal arm too much and crushed it,
D8veh, I don’t think this one has a led light.
There’s a small screw behind the sticker, I almost broke mine trying to force it apart before finding thatI did the same initially, disassembled it and applied some lithium grease then put back together. It still to rotated smoothly after that. Was surprised in doing so to only find 6 magnets in it, aren’t these supposed to have 12?
I can confirm that this is the case and it outputs 12 pulses per revolution.I think they have dual sensors. Maybe 2 x 6 =12 pulses.
