No. E-bikes are restricted to 250W to be road legal.
Crank drive bikes can go up 15% hills slowly, hub drive bikes can go up 10% hills, 15% hills with hard pedalling. To go up 15% hills at 15mph, you'd need the BBS02 500W or BBS02 750W.
Trex....you know what you have stated is rubbish,I thought we had educated you away from such unqualified statements.
The truth is that some crank drive motors are very low on power,they have to be ridden like a normal bike to get the best out of them,if you get caught in the wrong gear they may even stop up a hill.
Crank drives have one big problem that the power of the motor and the power of the rider is all being fed through the gear system of the bike-at maximum motor power with a rider standing on the pedals the chain is under considerable strain and a smooth dérailleur gear change is all but impossible. It is necessary to back off the power,especially on steep hill downshifts,Generation 2 Bosch automatically backs off the power,when gear changing,when the chain is under strain but this can result in a lack of momentum up hills. However the better crank drive systems do create an intuitive ride,sometimes the assistance is so subtle that it's difficult to detect the help. Crank drive bikes are not the best hill climbers.
The best hill climbing EN15194 legal e-bike is the KTM Panasonic 48v hub bike,we proved that at the Redbridge test day, but it costs around £2k.
Not far behind that bike are all the BPM hub drives such as Woosh Bear,Kudos Arriba-Tornado,Oxygen e-mate etc etc
The great advantage of hub drive is that the power of the motor is fed into the wheel independent of the rider power so that the bikes gearing system is not being asked to handle the motor power. Obviously that means that the torque of the motor cannot be changed using the bikes gears,but the torque spread of the BPM motor,especially at low road speed is so wide that this makes little difference.
BPM hub drive bikes are the best hill climbers.
There are some hub motors which I would describe as medium power (the SWX type and their clones),these motors are generally inexpensive they do an ok job for many people and the bikes are overal good value,this type of e-bike is probably 70 per cent of the marketplace.
I apologise for being so definite about this but this forum has flogged this subject to death and there is so much misinformation,especially from Trex,which leads customers to buy the wrong type of bike.
Bosch,Shimano,TCM and Yamaha crank drive equipped bikes are often beautifully engineered and delightful bikes to ride but they are not the most powerful legal hill climbers.
KudosDave
