My bike seems to have developed a fault and I was wondering if anyone could point me in the right direction to track it down. I rode home the other morning fine and put the bike on charge. When it came time to go to work the battery appeared to be charged and the charger light was green. Upon getting on I found that the motor was not running and several times upon turning the key to the "on" position resulted in a clunking noise and the power indicator on the handlebars going off. I have not had the chance to track down where the clunking sound is coming from, the hub or the battery but will be investigating further in a couple days to try to repair whatever the issue is. The power does not always go off when turning the key though it still won't run, and when it stays (most times) on the battery indicators on both the handlebar and the battery housing indicate a full charge, plugging the battery into the charger gives a green fully charged light.
My bike is Chadwick&Taylor. Bought it second hand a month ago and it was working fine. The same model was discussed here before and some photos are attached in this post: https://www.pedelecs.co.uk/forum/threads/how-i-can-increase-max-speed-of-my-bike.30590/post-426372
Any help would be appreciated and thanks in advance!
Paul
Paul
