My BBS02 500W has been running fine for 3 years and I only use it for road use so it has had an easy life. Yesterday I had a fault and wondered is it related to when I disconnected the battery before switching it off and maybe causing a power surge when I lifted the battery from its holder.
I have the C963 display and now it permanently shows level 1 assist and the display buttons do not respond. That is the power, plus and minus buttons are unresponsive. Luckily when I connect the battery the system automatically power on but stuck in assist 1. There is no error code showing. The throttle still works so I can use that for more power.
I've checked for loose connections and the battery contact. Not sure if the display module is faulty and don't know if it can be tested with a meter to confirm before splashing out for a replacement.
Has anyone had the same fault or know how to fix this?
