Help - kit recommendations for Raleigh Twenty
17,150
Would this be an issue if the rear wheel is a slightly different size to the front?
problem is you have rim brakes. Have to have the correct rim size.
Reactions: Bumtreq
Amoto65
807
502
Cheshire
Would this be an issue if the rear wheel is a slightly different size to the front? Also, any recommendations? I’m hoping for a 1000w as I’m quite a heavy rider, but open to options and suggestions.
A 1000w is going to be illegal also you will have to modify the rear drop outs to do that and lose the 3 speed Sturmey Archer gears. I have seen a few conversions with front wheel drive, plus a significant amount of 20" wheel electric bikes are front hub motors. I used to own a viking 20" front hub electric bike and wish I had kept it to convert my Raleigh.
17,150
I have 406 rims. Not sure you can fix the brakes. Relacing the motor may be an option.
What is the width of the dropout?
Forty45
27
Hampshire
If you really want a bike of this type and era the Dawes Kingpin would be better because alloy rimmed wheels are available I think. Doing anything to a Raleigh is difficult because it is either Raleigh specific, imperial measurements, or unobtainable usually.
Amoto65
807
502
Cheshire
Both the Raleigh and the Dawes Kingpin use the same wheels.
17,150
The ground clearance is probably a bit low for a mid mount kit,
check the cranks' length.
If it's 175mm then a mid drive is worth considering because the conversion keeps the existing wheels and brakes and has simple wiring.
Amoto65
807
502
Cheshire
Mid drive conversion would be very tricky due to the fact the bottom bracket has Raleighs propietary 26 tpi size and the shells are wider than standard at 76mm unlike the Dawes Kingpin which are standard.
17,150
I see the problem.
the TPI is not important because most of the bottom bracket motors except the Gospade don't use the BB thread. 76mm may still be possible if you can find a way to lock the M33 nut.
Still, finding another donor bike may turn out to be more economical.
MikelBikel
1,611
386
Info on standard bike above & other places.
Like others have said its got proprietary sizes on everything. 80mm-ish wide fork. Need 'Dropbolt' mod to fit decent double pivot calipers, Koolstop Salmon brake blocks and preferably 406 alloy rims for wheels. Bottom bracket is 75mm-ish wide & not BSA std. Rear dropout is 114mm-ish width. Etc. Etc.
Doable, take lot of work, but it'd look cool. :cool:
Reactions: Bumtreq and Woosh
Jimmysmooth
Jan 29, 2020
I installed a Bafang BBSHD on R20 recently.....machined 5mm off drive side of BB. Worked out well. I did weld on rear brake bosses for cantilever brake. Safety first , I don't think original brakes are up to the task.
Spinnanz
56
17
I've done an electric conversion too, but to a Raleigh sport. If I was to do a Raleigh 20, here is what I'd do...
To keep the 3 speed rear hub I'd go with a 250w front hub, however I'd get a hub thats made for a larger rim, like a 26", and have that laced to your smaller 20" rim.
The size difference between these two wheels is 22%. This will have the effect of giving your more 22% more torque, although it will reduce your top speed by 22%. Top speed is normally 30-35kph on an average 250w hub, so the new top speed will be 23-27kph, perfectly speedy enough for a Raleigh 20!
For the battery id find a 1970s saddle bag, or make a flat cell pack to go in the bottom of your wooden box. A small 10ah battery will EASILY get you to and from work. The longest ride I've done so far is 50km.35156
Reactions: bagss2
glawsder
May 7, 2020
Agree with a front hub, less hassle- I have just fitted a yose front hub to a trike for under £300, with the following points to note.
Your bottom bracket probably won't take the cassette PAS, and a 2 piece PAS unit will be required.
The threads and nuts on the new front wheel where wider than the original, you should check it can fit the Raleigh before buying. The frame was OK for mine, but I had to 'adjust' the mudguard and front basket fittings.
The biggest issue will be fitting the PAS unit, ensuring there is enough space for the disk on the crank so it spins and getting the spacing for the sensor to read it (there wasn't on the trike and I ended up taking a Dremel to the disk and glueing it to the pedal).
toppy007
Sep 17, 2020
This is my conversion of a shopper. 1000w Rear hub, 15Ah battery
Its on instructables so you can see how the conversion went
Reactions: MontyPAS
Swizz
211
161
49
Sk14
Did the same to a 20 to fit a square taper bottom bracket axle. When I say 'machined' read 'carefully fettled with a flap disk on an angle grinder'. It worked well enough.
Our 20 had the non drive side bearing cup welded in though, which for a mid drive would be further action with the grinder.
