Headway Battery
mavmac
Oct 19, 2011
My Headway Bike is very good but I now need a new battery but can not find one in the UK
30,602
You can try contacting the Headway battery company Zhejiang Xinghai direct about their e-bike batteries. Normally these companies are only interested in importer inquiries but they may be able to direct you to a source. Here's their contact page:
Headway bikes and batteries
P.S. You can use other makes of battery of course and arrange new connections. Is your model the carrier or rear of seatpost battery version?
mavmac
Oct 19, 2011
I contacted the company in China, not heared back. The battery is at the rear under the seat
30,602
That is a common problem with many Chinese companies, unwillingness to provide even the slightest aftermarket support to indiviuals.
If you are unable to find the correct slot-in battery eventually, one solution is to use another make and mount it on the carrier, arranging cable connections to the bike's own battery base connectors.
