Have I got the wrong controller?
Sparksandbangs
11
Bought one of these
I have a bafang 250w motor.
Wired up and during the self learn the wheel judders forward a bit and then nothing
Shows a motor error. If I set off the PAS the wheel rotates at a slow speed as it should.
I'm at a bit of a loss at the minute and the only thought I have is to switch out the controller.
36v if that is any help.
8,692
Check controller connections and especially the motor coonector , is it pushed home all the way ?
Also try repeating the learning to see if it finds better syncing.
Sparksandbangs
11
Motor connections seem fine. Also with the 4mph push assist working wouldn't that rule out the connections being lose?
3,551
Bought one of these
Please write that again in a way I can understand it. Do you mean that when you disconnect the pedal sensor, the self learning works? If so, you have the wrong wiring sequence on your pedal sensor. Check that it goes red to red, black to black and blue to whatever. You should also check that you have the hall wires in the right sequence, as sometimes two colours are swapped.
Don't forget that each time you do the self-learning, it reverses motor direction.
Sparksandbangs
11
Sorry I didn't mean pedal assist. I meant the push assist at 4mph. Typing while stood out in the cold. Brain not working properly.
Sparksandbangs
11
As an update. I couldn't get it to work. Swapped out with a KT controller and no problems. Should have got one in the first place. Just needs the settings tweaking to get it how I would like it. Thank you for your help.
8,692
We always recommend KT over nay other after market controller kit, one gets what one pays for and with KT one can't go far wrong.
In the bigger picture of things paying 40% more for a KT over the cheaper speed controllers is a win win.
